Tranny Woes
Old Nov 18, 2008 | 09:50 AM
1Digger's Avatar
1Digger
Tranny Woes
OK, here's the problem. I have an 01 Ranger Edge, 4.0, auto 2WD. I bought the truck in May with 88K on the clock. No real troubles until recently.
When running uphill and into a slight headwind, the truck will downshift lazily and the O/D light will start flashing. I know that this is the limp home mode. When I shut off the truck and restart, the light is off and everything is fine again until I get into the same situation.
OK, so is the tranny due for a rebuild/replace? Will a fluid and filter change even help? The upshifts/down****s seem slow, will a shift kit help?
Any help will be appreciated!
Old Nov 18, 2008 | 04:20 PM
pawpaw's Avatar
pawpaw
Have you checked the tranny fluid level & condition????
Has the filter & fluid ever been changed????
Old Nov 18, 2008 | 04:48 PM
herman391's Avatar
herman391
Precisely what I was going to ask
Old Nov 19, 2008 | 08:55 AM
1Digger's Avatar
1Digger
I haven't done it since I have owned it, but it is on the short list of things to get done.
BTW, I installed the Autolite Double Platnum plugs in it and it is like a whole new truck! I bet I picked up 15HP!
Old Nov 19, 2008 | 09:05 AM
Bear River's Avatar
Bear River
Former ******
That should should have been replaced at least twice in the last 80,000 miles. There is a design flaw that these transmissions have. It has to do with the way the solenoids wear into the transmission body. This causes fluid to leak internally. The solution is to get the tranny rebuilt by someone who can install brass bushings into the housing to address the wear. Most tranny shops don't do this, and the dealer definitely does not. If you get it repaired properly, you should never have a problem again, under the conditions that you change the fluid at the recommended intervals.
I can't say for sure that is what your problem is, but it is really common, and OD is one of the bands that is engaged by said solenoid. So if that solenoid starts to leak, there is not enough pressure to engage OD, and the trans starts slipping. The computer detects the slippage and switches to limp mode to prevent further damage.
jk080's Avatar
jk080
Transmission Rebuilder
I would check to see what code is set, it will give you a direction to go in.
I would do this before anything else, there is no need to waste the time or money on a service if the problem will require a rebuild.
Old Nov 19, 2008 | 03:26 PM
wtroger's Avatar
wtroger
There are some known issues with the valve bodies on these trucks. There is an extensive thread on here about it. I fixed one for under $300.00 by replacing the valve body. With a one from these folks Central Valve Bodies - Remanufactured Valve Bodies It has all the upgrades to combat the leakage issue plus new solenoids.
Old Nov 20, 2008 | 09:27 AM
Bear River's Avatar
Bear River
Former ******
A remanufactured valve body will not correct the leakage around the solenoids that operate the bands directly. These wear into the transmission case itself.
Old Nov 20, 2008 | 09:35 AM
1Digger's Avatar
1Digger
I went to Advance right after the last time this happened. They told be they could only read a code if the check engine light was on. I didn't think that sounded right, but they were busy and I figured they just didn't want to do it.
What would a rebuild cost with the upgrades, roughly?
Old Nov 20, 2008 | 10:26 AM
pawpaw's Avatar
pawpaw
Loosen the gas cap, to turn the CEL on, during the drive back to Advance to have the computer scanned for codes.
Old Nov 20, 2008 | 11:17 AM
jk080's Avatar
jk080
@ 2K
Still have the codes checked before anything else
Old Nov 20, 2008 | 02:53 PM
1Digger's Avatar
1Digger
Oh man, I only paid $7K for the truck (wonder why!)
I'll get the codes checked and report back
