Engine swap ?
Old Nov 17, 2008 | 01:41 PM
sanfortandson's Avatar
sanfortandson
Engine swap ?
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">A buddy of mine has a 1986 f-150 302 fuel injected that is basically wore out. I had a 1989 351w carb motor out of ford ltd squad I sold him. ? what would it take to make the 351w carb motor work in place of the 302 fuel injected motor. can we bypass some of the wiring, change fuel pump or just P------s in the wind try something different. All question and answera welcomed.
</TD></TR></TBODY></TABLE>
Old Nov 17, 2008 | 04:11 PM
Kemicalburns's Avatar
Kemicalburns
stay efi and go to the wrecking yard and get all of the 5.8 efi stuff. you will need the upper/lower intake, distributer from efi 5.8 as well. you can still use the efi 5.0 harness and injectors. get a 5.8/C6 ecu then check out Ford Fuel Injection for any wiring questions.
Old Nov 18, 2008 | 09:44 AM
sanfortandson
swap
I'll check into that.
Old Nov 18, 2008 | 11:16 AM
Kemicalburns
you will also need a flexplate from an 89 crownvic running a 5.8/AOD.
trust me staying efi will be easier and better in the long run. the gain in mpg with efi over carb is totally worth it.
