Np 435 Mt???
Old Nov 17, 2008 | 12:17 PM
secondarychaos's Avatar
secondarychaos
Np 435 Mt???
Hey all,
did your years of trucks come with the NP 435? if so, what transfer case came with it?
thanks in advanced!
Dan
Old Nov 17, 2008 | 12:26 PM
Dean88's Avatar
Dean88
My 87 had a T18, but an 85 I drove for a short time had the 435.
Old Nov 17, 2008 | 01:27 PM
secondarychaos
Thanks for the response. If yours had 4x4, what tcase did it have? if you know...
Old Nov 17, 2008 | 04:14 PM
Oscar Meier's Avatar
Oscar Meier
My '85 4x4 has the NP 435 & NP 205 transfer case.
Old Nov 17, 2008 | 04:23 PM
kickingber's Avatar
kickingber
My 83 F250 4x4 has the NP435 mated to a borgs warner 1345 Transfercase.
Old Nov 17, 2008 | 04:38 PM
Franklin2's Avatar
Franklin2
I don't believe any of the 80-up trucks came with a 205 transfer case. They used the New process 208 or the Borg warner transfer cases.
Old Nov 17, 2008 | 05:56 PM
82F100SWB's Avatar
82F100SWB
Yep, the 205 was last factory installed in 79. That said, pretty much any married pickup transfer case will interchange. Ford used the same bolt pattern and shaft size/spline count on all it's transfer cases 80-97 inclusive, no matter what transmission it is behind,
Old Nov 17, 2008 | 07:30 PM
Ed_B's Avatar
Ed_B
My '84 F250 4x4 has the 300 I6 + NP435 trans + NP208 xfer case.
Ed
Old Nov 17, 2008 | 08:01 PM
secondarychaos
Thanks for the info guys.
I'm doing a dual transmission on my yota rockcrawler. the stock yota tranny + NP435 + NP205 + stock diffs = 220:1 crawl ratio....
Old Nov 19, 2008 | 08:34 AM
bashby's Avatar
bashby
So are you guys using a divorced np205? I have been thinking about doing that with my 2wd f350 dump truck just for the low range. I have a 351w slightly built/ c6 and 4.10 gears and sometimes on the job sight I need lower gearing to get in tight spots. It's a long wheelbase truck so I have plenty of room to mount up a divorced case, plus a friend has one I can get free(not sure what model) I'd love to see some pics of some divorced cases and how they're mounted or a link to an install.
Old Nov 19, 2008 | 03:34 PM
bashby's Avatar
bashby
I think I'll start a new thread in drivetrain... sorry about the hijack
Old Nov 19, 2008 | 05:03 PM
uncle.stosh's Avatar
uncle.stosh
2 transmissions is not the way to go and doesn't make any sense. How could you possibly shift the NP435? Plus, it's huge and very heavy.
If you want, run a doubler. An NP203 range box bolted to an NP205.
That is the best setup.
Sorry but I doubt you are very serious based on your lack of knowledge on the subject, plus the fact that you mentioned "stock diffs" and rock crawler in the same sentence.
They (stock differentials) won't last 2 minutes on the rocks.
