Sponsored by: Auxito
How to replace Wiper??
Old Nov 16, 2008 | 10:46 PM
wildchild04's Avatar
wildchild04
I have a 1999 F250 LD, I think I need to replace my windshield wiper. How do I remove the wiper??
Does the cap pry straight up, to get to the nut, or..??
Old Nov 17, 2008 | 08:21 AM
galaxie641's Avatar
galaxie641
I assume yo mean the arm. You pull the cap off, there is a small slot on one side where you can get a screw driver in to pop it off. Then there is a nut to remove. Then the arm pulls off a splined shaft, that will be the hardest part.
Old Nov 17, 2008 | 10:16 AM
wildchild04
Thank you Galaxie641
Yes, the control arm is what I was thinking of. Looks like it's time for a new one, as the spines on the control arm side are stripped out.
Old Nov 17, 2008 | 06:15 PM
Bobby82490's Avatar
Bobby82490
Alot of times you can just retighten it and it will work again.
Old Nov 17, 2008 | 06:31 PM
fireball 440's Avatar
fireball 440
x2. Those nuts loosen up quite often.
Old Nov 17, 2008 | 09:27 PM
wildchild04
control arm
The control arm is stripped bad, bout as smooth as a baby's rear. There is some wear on the other spines, but hope it will hold with a different control arm.
Old Nov 18, 2008 | 05:05 AM
Bobby82490's Avatar
Bobby82490
Mine is completely stipped too, but the wiper arm shaft is tapered. So the tighter you tighten it the less likely it is to slip. Even though mine has NO splines left, I just tightened it down real good and it has been working good for probably 1 yr.
If it works good in FL where it rains alot and the wipers are used alot, im sure it would work for you.
Old Nov 18, 2008 | 11:25 AM
Eatonpcat's Avatar
Eatonpcat
Just retighten the nut... The replacement part will not have splines. I bought a new arm thinking mine was stripped also.
