repeat fuel pump failures
Old Nov 16, 2008 | 09:27 PM
cfitzpatrick's Avatar
cfitzpatrick
1997 f-250 4x4 duel tanks,240,000 miles,replaced original pump after engine lost power when filrer light was on eventually died no restart.All lines have been checked for leaks or restriction.Haved replaced filter base and regulator all rubber lines at pump,replace second pump same failure.High pressure side of pump failing.Anyone had this probelm
