Need a Part Number
Old Nov 16, 2008 | 06:10 PM
Drac's Avatar
Drac
Save the old ones
Need a Part Number
I have an '86 F-250 4wd I am looking for the part number of rear brake line Load sensing valve.
It mounts to the frame above the rear axle. It has a splined shaft where a arm link attaches to the axle. I suppose this valve increases braking power when heavily loaded. Also limits rear wheel lck up when empty.
Anyway mine is rusted into bits
Old Nov 16, 2008 | 07:56 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You should post NumberDummy's name in the title of this kind of request, or just PM him....
Old Nov 16, 2008 | 07:59 PM
Franklin2's Avatar
Franklin2
I think ftepartsguy.com may have it for $149.80. I plugged in your truck, selected brakes-hydraulics-pressure metering valve. You may want to call them to make sure that's the correct piece. Hopefully that's not the proportioning valve up front.
Old Nov 16, 2008 | 08:49 PM
uncle.stosh's Avatar
uncle.stosh
So that's what that do-hicky thing is back there.......
I always wondered what it was fer'.
Old Nov 16, 2008 | 10:27 PM
86bigred's Avatar
86bigred
me too, the leaver is broken off the diff side. i guess i should fix it. thanks
