Leveling coils not what I expected
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
I would recommend you contact Skyjacker and speak to them about your situation. They determined mine right away and may be able to do the same for you.
Mike
93' F-150 Ext Cab 5.0L E4OD, MSD, K&N, 31x10.50's
rbrendel, I got my spacers on ebay, however I did not get the stud extenders with them. I would recommend you try AZ4x4f150, from this forum. He sells them as well and it will be cheaper in the long run than buying the spacers and extenders separately.
Skyjacker does not have a tech line e-mail address that I am aware of. Give them a call first at (318) 388-0816 to speak to someone directly and let them know you want to send them pics.
Mike
I don't know what "he said it was because the 2wd are made to ride real low in the front, ALL THE WEIGHT ON THE FRONT ARE ON THE SPRINGS" is suppose to mean. The SPRUNG weight on a 4x4 and 4x2 are the same. Its the UNSPRUNG weight of the 4x4 ttb axle thats different. In case you don't know the difference, unsprung weight is below the springs, sprung weight is above the springs(anything the springs are holding up).
"fords are horrible about sagging springs fast especially the 2wd models"-----this line isn't true. Fords arn't horrible about sagging springs, whats makes you conclude this? Again, the springs on a 4x4 are the same as a 4x2.
"because they were not made to have any lift in the front stock whatsover"---this isn't true either, it doesnt make sense, a 2wd is built exactly the same as a 4x4, you could bolt a TTB 4x4 in place of the twin I-beams and its the same. A lift kit for a 4-6+ lift kit is the same for a 4x4 or 4x2. Same brackets, parts everything (except radius arms). ITS THE SAME...
I know a lot about the differences between a 4x4 and 4x2 because I was about to convert my old 2wd into 4x4. Its really easy when you think about it, simply because everything is the same. You unbolt the 2wd, get it out. You bolt in the TTB, hook up the radius arms, and your good to go suspension wise. (thats the basics) The parts are interchangeable and its a direct bolt up.
I can't explain why superlift has different springs for a 4x4 and 4x2. There is no reason why, i have no clue. Not considering the front axle and transfer case, a 4x4 and 4x2 weight the same, its the same truck, thats why stock, both a 4x4 and 4x2 have the same springs. When I bought my 4" superlift kit, they had a different 4" front spring for an extended cab vs regular cab, but NOT different springs for a 4x4 or 4x2.
Again, not considering the axle, a 4x4 has roughly the same weight on the front as a 2wd does. The differences in front and rear height are the same for a 4x4 or 4x2. My truck has a 2.5 inch difference in height from front to back. The 2wds have the same difference. So therefore, there isn't anymore weight on the front of a 2wd as there is on a 4wd.
This is a mouthful, and i hope you can follow along, if not, i can straighten you out, even i had trouble understanding this, its a confusing topic.
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
But, it might be the problem.
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
Mike
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
Primary rig is:
.Pictures are in!!
Then theres:
99' Mustang GT 4.6L
