As suggested, i started a new thread for the truck problems.
preppypyro- i was reaching for my purse after my dog knocked it off the seat. when i looked up, they stopped, and well..i didn't. it was an idiot move and i'm paying for it. well.. I could be wrong but i'm pretty sure that the bellhousing is removable. As to what i'm looking at in the door jam, i have no idea.
stangbanger- i just confirmed that the mounts are just broken. So shouldn't be too hard a fix.
Kez, what your looking for is a sticker that tells the serial number and has a bunch of codes on it. It will have your rear axle code, and a tranny code, paint code and a bunch of other stuff. Should be on the drivers door jam.
Ill show ya a picture of the tranny I have which is a AOD.
Do you know where yours is broken...? Or maybe its just cracked and it can be welded...?
i haven't tried to drive it. when the accident happened it didn't shut off or anything. but since i pulled over to get info. and saw all the tranny fluid and water from the rad i didn't try to mess with it. since the fan is in the rad i don't think it would be too good an idea to start it. i've tried by hand, and the fan won't turn.
i hope the picture comes up..
i don't know anything about the tranny. i can't even tell where it is damaged..
