neural safty switch bypass?
Old Nov 16, 2008 | 11:13 AM
Nate4.2's Avatar
Nate4.2
ok i have a 84 f150 and i think my neutral safty switch is bad dose anybody know how to bypass that any help would be greatly appreciated
Old Nov 16, 2008 | 11:37 AM
Holmesuser01's Avatar
Holmesuser01
You should just replace the safety switch. Thats why it is there.
Old Nov 16, 2008 | 03:34 PM
Franklin2's Avatar
Franklin2
If you have an automatic, the switch is on the side of the tranny. Find the two red/blue wires and twist them together.
Old Nov 16, 2008 | 03:45 PM
Sycostang67's Avatar
Sycostang67
If you have a standard tranny, the switch is on the clutch pedal. The wires will be the same color as an auto, red/blue. Just disconnect the wires from the switch and connect them together. If you want a cheap anti-theft device, buy a regular on/off switch from an auto parts store and mount it somewhere hidden. Hook the wires to the switch and there you go.
Old Nov 16, 2008 | 04:24 PM
uncle.stosh's Avatar
uncle.stosh
If you are just going to test the switch then just poke a piece of stripped wire into the connectors on the side of the tranny like suggested.
I would not permanently run it like that though. Someone could get hurt.
Old Nov 18, 2008 | 05:59 AM
Nate4.2's Avatar
Nate4.2
hey thanks guys bypass worked great. i did price a new switch and it was presty expencive maby i can fing one at a salvage yard.
