Sponsored by: Auxito
'01 150 Cold won't start
Old Nov 15, 2008 | 01:00 PM
fbodyfan's Avatar
fbodyfan
Hey guys! I have an '01 F-150 5.4 sittin at a buddy's house because it won't start. This has been doing this to me for ~2 weeks now on cold mornings. Here are the conditions:
Engine cold, temp outside cold: Cranks normally. After 2-3 seconds of cranking, starter sounds like it disengages. Spins, but not turning over engine. Starter is cranking engine just fine, but engine won't "catch". If I gas it while cranking, it will rev, but as soon as I let off the pedal, it dies. Speed/sound of starter sound normal to me.
Hot engine, regardless of temp outside: Runs like a champ
The past few weeks I've fought this condition. Priming, turning key on and off a few times then starting it, so on and so forth, I fought it and it worked. Now, no joy. Any ideas?
Old Nov 15, 2008 | 06:52 PM
Bobby82490's Avatar
Bobby82490
Originally Posted by fbodyfan
.....If I gas it while cranking, it will rev, but as soon as I let off the pedal, it dies. Speed/sound of starter sound normal to me. Hot engine, regardless of temp outside: Runs like a champ....
This makes it sound like the Idle Air Controller(IAC) is bad.
Old Nov 15, 2008 | 09:52 PM
LxMan1's Avatar
LxMan1
Starter bendix is kicking out. Try holding the pedal down about 1/4 inch and see if it will start. If not, then the starter is bad.
Old Nov 22, 2008 | 06:34 PM
fbodyfan's Avatar
fbodyfan
Just got it fixed, it was the IAC. Thanks for your input!
mOROTBREATH
18
Sep 24, 2013 07:01 PM
Krazymaan
Jan 4, 2011 06:38 PM
hutch1973
Mar 27, 2010 02:47 PM
GonzoCSU
Feb 3, 2010 08:54 AM
flatheadfreddy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 7, 2004 07:49 AM
