Water pump ??
Old Nov 15, 2008 | 05:57 PM
vettdvr's Avatar
vettdvr
Originally Posted by Kwikkordead
What I fail to understand is the reason that Ford decided to make two different styles of upper radiator hose, with the most common application the pass through type hose.
DOH!!!
Lets see,,, UHMMMM,,
Ford stock $2.00/sh or thereabouts.
Selling products not in tune with world economy (priced too high against competition).
Then trying to cut corners and save a few inches of rubber to cut a few cents off each truck to save a little $$.
I bought the optional hose to replace mine so I would not have to remove the hose to change a fan belt. That would be really poor engineering to have to remove the hoses, drain the cooling system every time you change a hose.
I really despise the NUT behind the fan blade that has to be removed to get the pulley off the pump. Another better Idea I suppose.
Old Nov 15, 2008 | 07:39 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Hotwheelbill
This brings up another question. In the info link for installing, it shows some very wide/strong looking clamps. Does anyone have a link for heavy duty hose clamps. My local autoparts and HD just have the crappy ones.
T-bolt hose and T-bolt v-band clamps on Ebay LINK
Old Nov 15, 2008 | 09:54 PM
jdecker88's Avatar
jdecker88
WEll now that work is slowing down I am gonna try to get mine in. IT has leaked down to just below the min. mark and has stopped leaking like it was. I am gonna get it pressure tested to see if it is the pump or the seal. I am on a budget so I am gonna do the airtex and try to get the new hoses. How hard is the coolent filter to put in just reroute the line?
Old Nov 15, 2008 | 10:54 PM
PaysonPSD's Avatar
PaysonPSD
If you go with a non-SCA extended life coolant you do not really need a coolant filter. JMHO
Old Nov 15, 2008 | 10:58 PM
jdecker88's Avatar
jdecker88
I was going to go with Rotella but I am gonna settle for some Final Charge from Napa.
Old Nov 15, 2008 | 11:33 PM
PaysonPSD's Avatar
PaysonPSD
No SCA needed with the Final Charge so you won't need to filter out the silcate that drops out of the SCA. Just flush the system real well and you will be good to go. Don't forget to open both block drains.
Old Nov 15, 2008 | 11:35 PM
jdecker88's Avatar
jdecker88
IT was just drained and flushed in January, it was cheap pump that has went out. Hopefully I can get by without it.
Old Nov 16, 2008 | 03:49 AM
PwerStroke99's Avatar
PwerStroke99
Originally Posted by vettdvr
Filter? What filter? First I heard. I figured at 144,000 miles on the first pump was pretty good. But If i can make it last longer!.. Thank you for the info. Any specific type.
Bob Riley @ dieselsite.com sells a coolant filter for our trucks. very good kit. im putting one on mine real soon. make sure u buy extra filters, because u will clog them up for the first three filter changes,
Old Nov 17, 2008 | 09:05 AM
Supercab's Avatar
Supercab
Wink
Guys:FYI: My 99.5 came with a single alternator-(hose through the belt) and when I changed all my hoses, belt, and Tstat/housing and added the coolant filter from Dieselsite (and installed the around the belt hose) the coolant filter rubs the hose VERY closely probably crushes the hose 1/8-1/4 inch which I didn't like, so I went back to the through the belt hose, now I have at least an air gap in between. I do have a brand new GATES around the belt hose if anyone needs in please pm me.
Old Nov 17, 2008 | 11:17 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by Supercab
...the coolant filter rubs the hose VERY closely probably crushes the hose 1/8-1/4 inch...
Mine touches too, but it doesn't push it in quite as much as yours did. Not enough to worry about, in my case.
You have a PM.
Stewart
bulla
38
Jul 16, 2019 03:02 PM
nbl346
Mar 10, 2013 09:06 PM
mtl93ranger
Jan 29, 2008 09:32 PM
ponch37300
1997 - 2003 F150
Jul 9, 2007 01:22 AM
motobub
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 7, 2002 08:32 PM
