Sponsored by: Kumho
C-Bushing Installation???
Old Aug 2, 2002 | 02:02 PM
RichMan's Avatar
RichMan
I have a '77 F-150 4x4, and need to change the c-bushings so that my tires don't where out on the inside. I have several questions...
1. I have a 4" lift and called around to several 4 wheel drive parts shops, and one says I need a 4 degree positive and the other tells me I need a 7 degree. I am thinking about going with the 7. Any suggestions or input on this??? I am also going to change the radius arm bushing while I am at it.
2. Do I have to support the frame when removing the front spring? If any one can give me clear installation instructions, I'd appreciate it.
Thanks,
Rich
Old Aug 2, 2002 | 04:59 PM
seymour's Avatar
seymour
What exactly is a C- Bushing. I have a set of 30 X 9.5 on my truck with a 3" lift kit. My tires are also wearing on the inside. Just got a wheel alignment. Hope it helps.
1984 F-150 2 wheeel drive.
Old Aug 3, 2002 | 09:19 AM
79BroncoJD's Avatar
79BroncoJD
You need 4º C-Busings for your truck, Part # 4.7105R for red poly from Energy Suspension. This kit includes track arm, radius arm and c-bushings. You should be able to order it through your local speed shop. I just got one and on the back it states "The C-Bushings 4 degree offset is for use on 2" to 4" lift." They make black too.
www.energysuspension.com/fdt3.html
Old Aug 4, 2002 | 08:15 PM
ryant's Avatar
ryant
I notice many lift kits include axle pivot drop brackets to lower the axle pivot point and "correct camber angle". Using these brackets one would assume that the stock bushings may be ok for the alignment?
Old Aug 4, 2002 | 09:57 PM
Skyking's Avatar
Skyking
beaudog
Jun 29, 2016 07:19 PM
dadstan76
Ford Truck Parts for Sale
Apr 22, 2016 10:54 PM
GaMachinist
Feb 29, 2016 10:41 AM
ManfredVonRichtofen
Offroad & 4x4
Dec 3, 2013 02:20 PM
460 FORD MAN
Sep 29, 2012 04:37 PM
