How was your '78 grille and where are you located? I'm looking for one if you want to sell.....
I don't have the grill shell but I still can get it,I do have a perfect grill and headlight trim. I'm located in central Iowa and I would sell. I also have extra front marker lights if you need them-Rich
Dose that bad boy bolt right on? Im thinkin of doing that, not a big fan of the square lights.
You could always put the 78 Custom style round headlight buckets and lights in your grill also. Changes the look just a little bit, and looks cool imo....
The shell bolts right up but you will have to get the right headlight buckets which should be with the grill already. You will have to drill some holes but it's easy, just screw the headlight buckets to the grill install the whole mess and then drill holes.You will also have to change the top corner brackets for the turn signals
