High RPMs after fuel problem
Old Nov 14, 2008 | 12:05 PM
hinote_96's Avatar
hinote_96
4wd High
I have an 87 F150 302 4spd manual that I got from my dad. I went out to start it one day and it would turn over but not start. After much diagnosis I finally narrowed down the the fuel pump in the tank. Now that the fuel is flowing again it starts however it immediately goes to 2000 rpm and runs for about 1 min before it shuts off. I checked for vacuum leaks but didn't find any. After reading many posts the TSP or fuel pressure regulator. Any ideas?
Old Nov 14, 2008 | 01:09 PM
05chop's Avatar
05chop
What was your fuel pressure after you installed a new tank pump?
Old Nov 14, 2008 | 01:31 PM
hinote_96's Avatar
hinote_96
4wd High
I don't think I checked to pressure again after I installed the new pump. I had borrowed a tester and had already returned it. Should I check it again?
Old Nov 14, 2008 | 01:51 PM
05chop's Avatar
05chop
This makes a good mechanic checking his work.It wouldnt hurt to recheck the fuel pressure.Also did you check for fuel in the vacume line that goes to the fuel pressure regulator? These all are easy checks.
Old Nov 14, 2008 | 02:06 PM
andym's Avatar
andym
There's no way that an engine can run at 2000 RPMs unless the throttle plates are open or there's a severe vacuum leak.
Old Nov 14, 2008 | 02:16 PM
05chop's Avatar
05chop
How did you check for vacume leaks? hinote 96?
Old Nov 14, 2008 | 03:24 PM
Lazy K's Avatar
Lazy K
Vacuum leak gets my vote.
Old Nov 15, 2008 | 11:09 PM
hinote_96's Avatar
hinote_96
4wd High
as for vacuum leaks I just inspected the hoses for cracks/holes etc. Also, I'm gonna check for fuel in the vacuum line to the fuel pressure regulator. I'll have to reborrow the fuel pressure guage from my brother in law. I'm helping him install a rear axle in a ranger tomorrow afternoon so he'll owe me.....
Old Nov 16, 2008 | 03:53 AM
pfogle's Avatar
pfogle
That is where you would be wrong sir. If the TPS is bad and it's sending an elevated signal to the computer it will open the IAC and it will run at about 2k rpm. I had a 351wEFI do this to me a few years ago. We didn't have any of the tools needed to test the parts so I took it to family friend who was a mechanic. Replaces the TPS and all was well once again.
cbmule
Feb 11, 2014 05:05 PM
hammer65
Oct 16, 2013 10:50 AM
B-414
Feb 18, 2013 11:25 PM
marc21387
Jun 18, 2012 11:15 AM
Obtuse1
Aug 30, 2004 03:06 PM
