My bronco recently began makeing a clunking noise from the front driver's side while braking, in sync with my the wheel speed. Over a couple days, it got worse and started making noise not just when applying the brakes.
I jacked up the front, grabbed the tire at 12 and 6 o'clock and the drivers side was wobbling pretty bad.
I took the hub and rotor off to put new bearings in and found the the cage on the inner wheel bearing was torn apart. All of the bearing pieces fell out when I pulled the old seal off of the hub.
My Question is: anyone have advice for getting the old bearing races out of the hub? The outer bearings and race came out easiler, but I struggled with the inner race, trying to hammer at it every way I could, before I gave up and decided to use the old race with new bearings. I know this probably isn't the best idea, but I had to get the truck back up and didn't have time to take the hub over to a shop. But, I'd like to know for next time if anyone has a proven method.
If the race was good, I wouldnt worry. If it is brunneled, you got to change it. Usally, there is two cut outs on the back side of the hub that you can stick a long punch and beat it out. Alittle heat probubly wouldnt hurt. Once you get one inner race out, the other is alot easier to get at.
I took my hub to a hole in the wall mechanics shop that works on american cars and trucks. The charged me $20 to replace them. They used a special tool to press them in and a nice punch to get them out.
yup, yup. Just be gald that you didn't have to replace the roter, brake calliber, shoes, berrings, wheel seal, spindle, and the hub!! That's what haponed to me!! I was driving and my brakes got realy spungy all of the sudden. So I limped her home and jacked up the front end and did the "wiggle test" it failed.
It turned out that the berrings, both inner and outter, were disinitagrated and my spindle was chewn all to hell, my brake pad on the back side of the roter fell off so when I braked the piston was rubbing on the rotor, and the guts of the hub were disintagrated as well.
Its amasing that my tire didn't fall off!!!! When I took the hub cap off it looked like somebody took a lathe to the inside of my hub with a lil TNT.
I recon that that was one of her darkest hours.
