Is there a special tool for this?
Old Nov 13, 2008 | 10:31 AM
WALFORD'S 56's Avatar
WALFORD'S 56
Question Is there a special tool for this?
I am trying to tighten the power steering lines on the steering column from the power-steering pump.....and they are leaking!!
I have line-wrenches but the 5/8 wrench will not work on the rear line!! I wonder if there is a wrench or tool that works better-that I have not tried!!
Thanks........Bill
Old Nov 13, 2008 | 10:40 AM
WALFORD'S 56
Forgot---1971 sport-custom with p.s. and p.b.
and 302........why does Ford make this soooo hard to tighten/loosen?
Old Nov 13, 2008 | 11:51 AM
jowilker's Avatar
jowilker
What kind of setup do you have there bub? Lines on the column is new to me.
John
Old Nov 13, 2008 | 02:54 PM
BradyCouchman's Avatar
BradyCouchman
i think he is talking about the lines that go from the pump to the steering box (colum)....
Old Nov 13, 2008 | 04:06 PM
matejcekautoworks's Avatar
matejcekautoworks
i just used a regular wrench and it worked out good for me
Old Nov 13, 2008 | 04:51 PM
jowilker's Avatar
jowilker
I thought he was too, but as part of sensitivity training we don't call fingers, toes.
John
Old Nov 13, 2008 | 05:07 PM
WALFORD'S 56
Angry
I found a swivel line wrench that might do the job. It is a bear to tighten and I have no patience anymore. Thanks guys and wish I had smaller hands--and bigger feet--haha!!! Bill
Old Nov 13, 2008 | 11:49 PM
Danger_Dave's Avatar
Danger_Dave
blow torch! haha
Old Nov 14, 2008 | 10:01 AM
WALFORD'S 56
LOL
I tightened them up alittle but looks like a mechanic will have to give it a try. Bill
Old Nov 14, 2008 | 05:15 PM
mcdobson's Avatar
mcdobson
You are going to most likely have to replace them anyway so put a pair of visegrips on it and see if it quits leaking. When it doesn't, take them out with the visegrips and put the new ones in with a line wrench.
Old Nov 14, 2008 | 06:49 PM
WALFORD'S 56
They were replaced last yr.,and were leaking.....and My line wrench cannot completely tighten them up....did alittle better---hope that holds for a while...thanks/Bill
Old Nov 14, 2008 | 07:28 PM
dan76's Avatar
dan76
I'll bet the fittings are faulty....normally not a lot of torque is needed to properly tighten this type of thread. A line wrench is the preferred tool. Try to orient the lines during the new fitting install to ensure you can properly place the line wrench for easy torquing.
Old Nov 14, 2008 | 08:16 PM
DragonElectric's Avatar
DragonElectric
Neat trick and it works well without even cleaning the fluid off first. Liquid Teflon you can get it in any plumbing store Or big box stores. It must be teflon based. It will seal most leaks in any environment without having to over tighten them.
I use it all the time on conduit, HVAC piping, Gas piping and by the way on every fluid fitting or plug on my F-250. I don't leak anyplace I put the stuff. It even comes apart easier without falling apart.
Old Nov 16, 2008 | 11:54 AM
WALFORD'S 56
Now I need some of that stuff---LOL....I hate leaks. Bill
Old Nov 17, 2008 | 10:53 AM
mcdobson's Avatar
mcdobson
I bought some line wrench style crows foot wrenches. They work well because you use a ratchet and extension to turn the wrench.
