Sponsored by: Real Truck
LED Tail Light Wiring Question
Old Nov 13, 2008 | 09:03 AM
Flame Out's Avatar
Flame Out
On our '98 F-250 we converted to a flatbed and would like to change the stop, turn and tail lights to LED. Should I cut off the Ford OEM female recepticles from the harness and solder new conncectors (weatherproof, of course) in order to connect the LED pigtails? I have not seen any kind of aftermarket plug compatible with the Ford harness.
What have others done?
Old Nov 13, 2008 | 09:44 AM
patrickke's Avatar
patrickke
i believe thats your only option....id just save the pigtails just in case you wanna put the bed back on it....i just kind of wonder if it might need a capacitor
Old Nov 13, 2008 | 09:59 AM
Flame Out's Avatar
Flame Out
Thanks for the validation. This is new for me.
The LEDS are supposed to draw way less current than the incaedescent bulbs, although with four lights I should measure the demand. A capacitor might be a good idea.
Old Nov 13, 2008 | 10:09 AM
patrickke's Avatar
patrickke
after you put the heat shrink on i would suggest some wire looming to go on top of that just to cover your bases.... when you get done put up some pics
Old Nov 13, 2008 | 10:26 AM
SpringerPop's Avatar
SpringerPop
You won't need a capacitor. Unless, of course, you want the LED's to go out slowly, mimicking the old incandescents.
You may need resistors, however, to make the flasher unit work properly with the reduced current draw of the LED's. They effectively take the current draw back up to what it was using the incandescents.
An electronic flasher unit will eliminate the need for resistors.
Pop
Old Nov 13, 2008 | 10:31 AM
3000 FPS's Avatar
3000 FPS
A led tail light is a light emmitting diode and diodes are polarized and have to be connected with the positive on the correct lead from your truck. I am not sure what a capcitor is suppose to do in this circuit. The tail lights you get should already have limiting circuits in it for the led's so that they do not burn out.
Old Nov 13, 2008 | 11:28 AM
Flame Out's Avatar
Flame Out
Pop's suggestion about the flasher unit is a good one. I had forgotten about the electrical potential issue with the LED being such a lower draw.
Thanks for reminding me about polarity. I had not forgotten that DC systems are fussy about that. My first task once the new connectors are on is to test and label each lead. I was hoping to avoid that with an aftermarket snap on adapter but no such product.
I will post photos assuming there is a direct upload capabaility on this website. The offsite link for photos is beyond my capabilities.
Old Nov 14, 2008 | 07:30 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's "resistor" like Pop says
Old Nov 14, 2008 | 07:16 PM
Steve_250's Avatar
Steve_250
Check out this site, see if they have what you need.
Super Bright LEDs
Old Nov 20, 2008 | 09:25 PM
patrickke's Avatar
patrickke
bumped for a new user sorry guys
Old Nov 21, 2008 | 01:25 AM
Flame Out's Avatar
Flame Out
Finished the flatbed and fabricated steel boxes for the 4 inch round LEDs. THey work but are they bright! In fact, they are blinding- like Red headlights. This ought to cut down on tailgaters at night!!
The turn indicator circuit is blinking about twice as fast as normal- like when there is a short. I wonder if this fast pulse combined with the extreme brightness indicates there is too much current? I thought LEDs drew less amps than incandescent bulbs.
Or, maybe the 19 or so LEDs are just friggin bright on purpose.
Old Nov 21, 2008 | 01:47 AM
dew the thunder's Avatar
dew the thunder
You could only hope that's what it would do but such hasn't been the case with me. My entire back end of my truck is LED with the exception of the license plate lights and the reverse lights. I've even got one of them White Lightning tailgate bars. I've seen people at stop lights behind me covering their eyes though lol.
LEDs do draw less current and as a result your flasher relay is getting its power too quickly thinking there's a short, thus faster flashing. Add a resistor or look into different relays.
Old Nov 21, 2008 | 08:23 AM
Flame Out's Avatar
Flame Out
Dew, both you and SpringerPop suggested placing a resistor in line. My question is where? Is there a particular place that is best? Near the lights I guessing. How do I size the resistor?
This 12 Volt lighting is new to me. I barely understand 120/220 V AC systems.
Old Nov 21, 2008 | 10:50 AM
Bear River's Avatar
Bear River
Former ******
I just got a new flasher. Its easier than adding a resistor, and you don't have to figure out what resistance you need. There are flasher units that are designed for towing and LEDs at most auto parts stores. All you have to do is plug it in. the flasher module is under the dash most likely near the fusebox. When your blinkers are on you can hear it.
When you are in the parts store, just let the guy at the counter know you have LED lights and that you want a flasher module that works with LEDs, they should get you exactly what you need.
flamesoldier
May 3, 2013 06:37 PM
katiesdad7
Feb 27, 2009 11:59 AM
lfahey
Jul 2, 2008 07:24 PM
chaser1602
Electrical Systems/Wiring
Jan 29, 2008 03:54 PM
01expyEB
Aftermarket Products
Mar 9, 2004 01:30 AM
