Help Removing Fenders
Old Nov 12, 2008 | 05:20 PM
ironmine's Avatar
ironmine
Anyone remove their fenders?
My son is trying to remove the fenders on old '86 F250 that he is trying to fix up.
How many bolts? Bolt locations? Anything else?
Thanks in advance for any pointers.
Old Nov 12, 2008 | 05:31 PM
ctubutis's Avatar
ctubutis
IMO the best thing to do is to remove the plastic wheel cover thingers at the
same time, leave 'em attached to the fender and remove the assembly. In my
experience, those little screws are more of a PITA than the bolts. The bolts are
more or less easy, the hardest ones are down front by the bumper. In addition
to the obvious ones on top, there's one underneath, between the cab & wheel
opening.
-ct
Old Nov 12, 2008 | 05:33 PM
uncle.stosh's Avatar
uncle.stosh
Lots of bolts.
Hood springs have to come off, two up near the cowl, one inside the door, one underneath the rocker, two up top on the radiator support, two down lower by the radiator support, two on the metal strip between the bumper and grille and all of the plastic inner fenders unless you take them out at the same time.
The inner fender also has one large 10mm behind the wheel looking straight in.
It's a total PITA to get them (fenders) off.
Old Nov 13, 2008 | 02:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Here is a Diagram that should help you remove the fenders.
https://www.ford-trucks.com/user_gal...=97987&width=0
Just remember to remove the hood first, because just removing one of the hood springs will cause it to fall on your head.
There is also a very hard to reach bolt that you have to get at with the door open. About mid way up on the rear part of the fenders. It's shown in the diagram.
mechanicblue3
17
Oct 21, 2024 10:12 AM
vintshave
Jun 27, 2013 06:48 AM
Roelito78
Dec 29, 2009 05:13 PM
ghunt
Oct 13, 2009 03:36 PM
nsaikia
17
Apr 9, 2007 09:34 AM
