Head/Block compatability question
Old Nov 12, 2008 | 05:20 PM
tatonka04's Avatar
tatonka04
Ok, I just got a call from the machinist today and he said that the heads on my engine had a total of 4 cracks between them. Sooo, I'm down to 1 set of heads left.
Right now my build consists of:
- D3TE-1 block bored .030 over
- 2U cranshaft
- C7AE-B rods
- D5TE9426 KB intake
Can anybody tell me if the C8AE-H heads will work on my particular build?
Thanks for any info.
Old Nov 12, 2008 | 06:12 PM
Hypoid's Avatar
Hypoid
From what I've read about the valve spacing, you should be OK. Maybe someone else knows how big of a valve you can run without hitting the cylinders.
Old Nov 12, 2008 | 06:47 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep they will work fine. They are stock heads and used on various 68-71 engines. They are the smaller "velocity port" design as some call them. Valve spacing is std size and valve size is 2.05-1.55 in stock trim. The D2TE-6090-AA heads replaced them for 72 and up. Everything you have there is pretty much stock parts.
Old Nov 12, 2008 | 09:42 PM
tatonka04's Avatar
tatonka04
Cool, thanks again! This is yet another reason why I like this site so much! I figured somebody on here would know.This is my first attempt at an FE rebuild, so I'm still learning about the different part numbers, compatibilities and stuff. I'm pretty much just putting a stock build together. It all started with just a 360 regasket kind of thing, but then the deeper I dug, the more worn stuff I found, and then I saw a great deal on a 390 so then I decided that it would be best just to rebuild the whole thing as a 390 and forget about it.
The heads that I found out were bad, were the D2TE's.
So the smog tubes can just simply be plugged and call it a day? I'm hoping so because otherwise I'm looking at having to buy a new set.
Old Nov 12, 2008 | 09:54 PM
Redmanbob's Avatar
Redmanbob
yes you can get brass plaugs at a decent parts/hardware store. There is a post on here that contains the aprts # for the OEM but it's been about 5mo or so. And it may have been the 61-66 forum but pretty sure it's this one.
Old Nov 13, 2008 | 01:35 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
C8AE-H heads are physically the same as D2TE heads, the only difference is the lack of hardened exhaust seats.
And not to pick nits, but I thought the exhaust valves were 1.560" ? I remember, because the CJ/SCJ exhaust valves were 1.650", and the regular valves, the 6 and 5 were reversed...
Old Nov 13, 2008 | 01:40 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
On the air pump plugs, they should be 3/8-24 thread, go to a place that sells headless setscrews and get some that are long enough 1/2" or so. I plugged many a set back in the day. Works on Ford and Chevy air pump holes.
Old Nov 13, 2008 | 05:21 PM
tatonka04's Avatar
tatonka04
Ok, thanks for the plug info! I know somebody around here probably has them. I have come to really hate FE exhaust manifold bolts! On the now bad set of heads, I only had 4 bolts come out on their own. I had to drill and tap the other 12, just to find out that it was only for practice! Then, today, I had to pull the manifolds and the air tubes off these heads before they go to the machine shop. Luckily, I had the sense to start soaking these in penetrant for about a week now. I only had to drill and tap 3 today. Woohoo! I'm definitely better at it now, but I still don't like it! I digress, anywho, I thank yall again and I guess it's off to see the machinist guy.
Old Nov 13, 2008 | 05:44 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Well Art you can pick nits (isn't that a Russ sayin?) anytime you like!! Spec is 1.551-1.566 to be exact.
Old Nov 14, 2008 | 03:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Forget the brass plugs, they are not tapered, will leak and are too soft to do the job.
Since you can still get them from Ford, I suggest using the real thing.
8) C6AZ6052A .. Cylinder Head Exhaust Air Supply Plug / 1/2" -20 x 1 11/32" hex head.
Used to block off Thermactor holes in the head.
MSRP each: $5.10 / FTEpartsguy.com price each: $3.67
Old Nov 14, 2008 | 05:56 AM
tatonka04's Avatar
tatonka04
Hey Numberdummy, on that price, is that $3.67 for all 8 plugs or is that per each? Nevermind, it's early in the AM, I see it now!Thanks
Old Nov 14, 2008 | 06:09 AM
tatonka04's Avatar
tatonka04
One other question on blocking them off though. When I unbolted the air tubes, 2 of the "inner" air tubes actually came out of the block still attached to the threaded air tubes. Does it matter a whole hill of beans if they did? I guess what I mean is, does it change any of the dynamics and make it run better/worse because 2 cylinders have the inner air tubes removed? I suppose I could easily just push those 2 back into the holes, but pulling the other 6 might present somewhat of a problem.
WentzMetalWorks
24
Mar 9, 2025 08:36 PM
memphisjewel
23
May 10, 2016 04:54 PM
tbirdscott
Sep 15, 2015 11:13 PM
brownd019
Nov 1, 2006 10:17 PM
