Cluster Question
Old Nov 12, 2008 | 11:20 AM
crazycobra1969's Avatar
crazycobra1969
Cluster Question
My friend is junking his 95 Bronco and wantd to know if it would work in my 95 f-250 i know they have to be the same year I dont know about a bronco any input would helpful
Old Nov 12, 2008 | 11:28 AM
quicklook2's Avatar
quicklook2
it will.
i take it you want the tach.
got to articles/specs at top of page to find how to do it.
Old Nov 12, 2008 | 11:29 AM
TexasGuy001's Avatar
TexasGuy001
Just as long as both Bronco and F250 are gas engines. If the F250 is a diesel then the cluster would be different.
The compatible years are 92 and 93 / 94 and 95 / 96.
Old Nov 12, 2008 | 11:39 AM
quicklook2's Avatar
quicklook2
good point texas guy.
like i have posted at least a hundred times, the more info in your post about your truck or what is the problem or what you want to do makes it easier to help you.
Old Nov 12, 2008 | 12:06 PM
crazycobra1969
i already had a problem with a cluster from a 94 i put it in and the truck wasnt charging
Old Nov 12, 2008 | 12:09 PM
TexasGuy001
I don't know about any problems with that. I have a 95 with a 94 Lightning cluster. The only problems I know of is 92-93 don't have air bag so the warning/idiot lights are different. I know swapping them between 94 up years causes charging problems. Being your truck is a F250 it doesn't have an air bag does it? That means its compatible with 92-93 F150.
The Bronco would be the same as F150.
The other problem I know of is that 96 F150 is OBD II so they are in a catagory by themselves. As for F250 and F350 of 96 97 I think they are all OBD I like the rest of our trucks.
Someone correct me if I am wrong.
Is your truck gas or diesel?
Old Nov 12, 2008 | 12:16 PM
crazycobra1969
no theres no air bag and on the back of my orginal cluster the code on the back is E4 and on the one with a its E3
Old Nov 12, 2008 | 12:20 PM
crazycobra1969
its a 5.8 liter 4x4 with a E4OD trans
Old Nov 12, 2008 | 12:29 PM
TexasGuy001
If there is no air bag but your truck is gas, then any cluster from 92-93 F150 or 92-96 97 F250 F350 that is gas and not diesel and doesn't have an airbag should work. Of course you'll want one for and automatic overdrive and not for a standard because of the shift indicator delete. Although I think you should be able to swap your shift indicator over to another cluster if needed.
This is my 2 cents.
Thats about all I know. Maybe someone else can be more helpful.
Quicklook, do you know anything else about this swap?
Old Nov 13, 2008 | 01:58 PM
Muv's Avatar
Muv
You can definitely change the shift indicator between instrument clusters. I had to change mine on the replacement cluster I got when my speedometer/odometer started acting up.
Also thanks to the great guys on this site for putting info for direct swap of tachometer cluster for non-tach cluster. http://images.ford-trucks.com/forums.../party0005.gif
Old Nov 13, 2008 | 02:06 PM
pc_2000's Avatar
pc_2000
TexasGuy, My 93 F150XL 4x4 has an airbag and the indicator on the cluster.
Old Nov 13, 2008 | 02:12 PM
quicklook2's Avatar
quicklook2
94 was first year for airbag in 150.
if you have a 93 and it does have an airbag then maybe after jan. 1994 the law required them.
but a 250 does not have airbag.
Old Nov 14, 2008 | 08:10 AM
TexasGuy001
Are you sure its a 93 and not a 94? Does it have a 3rd brake light?
Air bags and 3rd brake lights weren't available until 94.
Old Nov 14, 2008 | 08:14 AM
pc_2000's Avatar
pc_2000
TG, no I do not have a 3rd brake light, but I do have the airbag light, and the steering wheel is an airbag wheel (although it is indented like the bag is missing, probably previous owner). Unless someone else swapped out the cluster before I bought it... hmmm
Old Nov 14, 2008 | 08:24 AM
TexasGuy001
Thats interesting. Maybe someone wanted to have an air bag so they had one (steering column and cluster) installed.
