300 - 302
Old Nov 12, 2008 | 07:49 AM
mudder84's Avatar
mudder84
i have a 84 150 with a 300 in it and a 3spd wit granny and it has no power to it and i have to have it in 2nd going like 25 up every hill (and i live in pennsylania) so i want to put a 302in it and i was wondering if the trany transfer case and everything else would match up or what would i have to get?? please help thankyou
Old Nov 12, 2008 | 08:03 AM
Conanski's Avatar
Conanski
Yes a 302 will bolt in, but you should look at your gearing first because if an I6 won't push the truck a 302 certainly won't. There's a good chance you have 3.08 or 2.73 gears, a change to 3.55 would help immensely, and if you swap the 302 in you'll need 3.73-4.10 gears.
Old Nov 12, 2008 | 09:14 AM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
That truck should at least be able to do that even if you have 2.73's. I would say there is something not right with the engine causing poor performance. Is the truck original? ie, stock motor, tranny, rear end, etc. .
Old Nov 12, 2008 | 09:33 AM
Econoline 150's Avatar
Econoline 150
Thats what Im thinking. I know they geared alot of vehicles too high in that era, but I wouldnt swap an engine out with just 2 more cubes before I checked everything over. Check the timing, the fuel pressure, and the compression to see if the truck shows any faults. The 300 running correctly has better low end torque.
conaski: I once helped a buddy do a gear swap on a milddle 80s F100 with 300 & 4 speed overdrive combo that had 2.47 gears, In overdrive it was not happy even on level ground. so, this could be the problem through big hills in Penn.
Old Nov 12, 2008 | 09:53 AM
Franklin2's Avatar
Franklin2
A 84 300 may have the computer control system which among other things, controls the timing. Lots of things to go wrong with that system. I feel it's a cop out to recommend to everyone that they ditch this system and put a regular distributor in, but if it were mine that's what I would do.
If you do not have a vacuum line going to the dist, then you do have the computer.
