service light
Old Nov 12, 2008 | 06:38 AM
COLD SHOT's Avatar
COLD SHOT
service light
I have a 03 explorer with a v6 recently service engine light came on ,the code reader says coolent temp below thermastat recirculating temp. anybody have any idea what might cause this? and what would be the fix?
Old Nov 12, 2008 | 10:39 AM
spikedog's Avatar
spikedog
What was the code number?
Old Nov 12, 2008 | 10:42 AM
COLD SHOT's Avatar
COLD SHOT
I didn't think to write down the code only the problem
Old Nov 12, 2008 | 08:55 PM
steve(ill)'s Avatar
steve(ill)
well, lets say you have a 195 degree thermostat, and the water temp only gets to 160 degrees ?? i would guess the thermostat is bad, leaking thru.
Old Nov 13, 2008 | 05:04 PM
marragtop's Avatar
marragtop
If it is the tstat, then your temp should be running a bit low.
Old Nov 13, 2008 | 05:29 PM
spikedog's Avatar
spikedog
Water pump not doing well?
