Sponsored by: Kumho
leveling kit
Old Aug 28, 2002 | 05:06 PM
fordman95's Avatar
fordman95
leveling kit
how hard is the leveling kit to put on i dont think i can afford a lift kit but i want a little bit bigger tires on my truck. i have the 2wd f-150 302 95
Old Aug 28, 2002 | 05:46 PM
MustangGT221's Avatar
MustangGT221
leveling kit
It's a snap. You need to remove the little metal clip at the top, that holds the spring in place at the top. There is a nut on the bottom, you'll see it in the middle of the spring. You need to unbolt that, and you're set. The bottom nut is 1 1/8, and I was able to remove it with a wrench and pipe for more leverage. You need to jack the truck up on stands. Then, with a floor jack, put it under the side you are working on. Put the jack there just enough to support it, don't put any tension on the spring. Unbolt it, remove it, drop the axle down more (make sure you leave enough room to be able to lower the axle more with the jack because the new springs are taller!) and install the new one in reverse of the removal. Tighten it up and you're set. As long as there is no tension on the spring, you're good to go.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 29, 2002 | 03:06 PM
blueoval79's Avatar
blueoval79
leveling kit
trevorrules
Jul 24, 2015 03:47 PM
guitarist41991
65
May 20, 2013 08:36 PM
DD1973
2009 - 2014 F150
Feb 4, 2013 03:54 PM
rpenterics
Jan 5, 2011 09:03 PM
Bigsilver95
May 17, 2005 12:51 PM
