Hemi Spankdown
Old Nov 10, 2008 | 07:35 PM
393STROKER's Avatar
393STROKER
Hemi Spankdown
It runs when it wants to. HP stroker ignition cuts out .TFI/getting hot.
Old Nov 10, 2008 | 08:00 PM
DJdemon6696's Avatar
DJdemon6696
uhh ? ....
Old Nov 10, 2008 | 08:51 PM
quicklook2's Avatar
quicklook2
very cryptic.
Old Nov 10, 2008 | 10:09 PM
gweeds's Avatar
gweeds
what does your post mean?
Old Nov 11, 2008 | 08:41 AM
guitarnik's Avatar
guitarnik
yeah huuh, what language is that
Old Nov 11, 2008 | 03:29 PM
gweeds's Avatar
gweeds
I'm almost certain that it's English. We are all just a bit confused on this one...
Old Nov 11, 2008 | 04:17 PM
skaterbro's Avatar
skaterbro
Hello
Old Nov 11, 2008 | 06:15 PM
393STROKER's Avatar
393STROKER
Whats up bro? I could use some advice. My`90 F-150 has developed some ignition problems. I modified the engine with just about everything. Now it will run for awhile until it warms up,then it will sudenly just die. I`m pretty sure the TFI module is gettin` too hot, but dont know what would be causing it.
Old Nov 11, 2008 | 06:19 PM
quicklook2's Avatar
quicklook2
let me go get my crack pipe fired up.
ok, i m bak but nuthin es makin cents.
Old Nov 11, 2008 | 06:27 PM
393STROKER's Avatar
393STROKER
What would caus the TFI modul to over heat
My truck will run real goood for about 15 min. ,then it cuts off. What the *&%# could it be?
Old Nov 11, 2008 | 06:36 PM
DJdemon6696
chek for codes.. or if your so shure. change it then!
Old Nov 11, 2008 | 06:43 PM
skaterbro's Avatar
skaterbro
They are susceptible to heat soak.
Old Nov 12, 2008 | 02:33 AM
TexasGuy001's Avatar
TexasGuy001
The TFI module has probably had it.
Is yours on the fender or distributor?
There probably isn't any grease on the back of it between it and the heat sink.
Old Nov 13, 2008 | 12:05 PM
BroncoRoadKill's Avatar
BroncoRoadKill
pickup coils can have that effect also, when they get hot then die cool down and run like a top again.
Old Nov 14, 2008 | 11:49 AM
1966Tbird's Avatar
1966Tbird
what have you done to it? i know that msd boxes will do this if they go underwater
