no lockup e40d
Old Nov 10, 2008 | 06:40 PM
l'il ol diesel's Avatar
l'il ol diesel
no lockup e40d
my 91 7.3 idi with a recently rebuilt tranny (professionally rebuilt) just stopped locking the torque converter. Does anyone know how to test the lockup electrical system??? Any help is appreciated.
Old Nov 10, 2008 | 09:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
l'il ol diesel,
Welcome to the IDI diesel forum.
I am not much on automatic trannies, but someone with one will be along shortly.
About all I can say is touching the brakes unlocks the torque converter, so are the brake lights on?
Old Nov 10, 2008 | 10:27 PM
ford trans tech's Avatar
ford trans tech
several things can cause it , after checking the brake light switch
you really need to scan it for codes
89-91 processors do not have the ability to flash the o/d light when a code is stored
Old Nov 11, 2008 | 08:39 AM
jas88's Avatar
jas88
Is it bang-shifting? This would indicate the computer has gone into failsafe mode.
Old Nov 12, 2008 | 09:36 AM
Purcell McCue's Avatar
Purcell McCue
My 90 F-250 did the same thing, I tested the TPS (FIPL) and it was ok, then replaced it and cured the problem. Mine was shifting between torque lockup and unlock. Even though the switch showed the correct voltage.
Old Nov 12, 2008 | 10:30 PM
ford trans tech
the fipl is the most common problem , your test passed it because your meter didnt have a high enough sampling rate
we have had for years what is called a noisy fipl issue
thats when at a cruise condition the vibration etc causes a worn spot in the potentiometer to emit a wide voltage pattern and there is also a code for a noisy fipl
Old Nov 13, 2008 | 12:39 AM
PLC7.3's Avatar
PLC7.3
I quote from my documentation:
DIESEL FIPL SENSOR INFO
DATE 1992
REASON
Early Black FIPL has High Failure Rate
RECOMMENDATION
Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL.
PART NUMBER
F2TZ-9B989-C
