tracing my leak
Old Nov 10, 2008 | 12:56 PM
otpracer100's Avatar
otpracer100
tracing my leak
Well, got the fpr rebuilt,gonna put some miles on her today. I had her running in the driveway and was looking for my oil leak near the turbo. I thought I saw a drop of oil come out of the pass side rear pedistal bolt. If this was the case would that be the pedistal o-ring leaking? Thanks.
Old Nov 10, 2008 | 01:02 PM
Neal 97 250's Avatar
Neal 97 250
The o-rings are not onthe pedestal bolts but that may be where it is running to. Not sure, those are hard leaks to locate.
Old Nov 10, 2008 | 01:05 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Could be or could not be, hard to tell until you pull it. Just ask RubberDuck & Norton72. Check this out: https://www.ford-trucks.com/forums/7...-finished.html
Old Nov 10, 2008 | 01:39 PM
Norton72's Avatar
Norton72
Yep, read that whole thread and make sure you do as Plowhand suggested in there and check for leaks by applying low air pressure to the oil ports after removing the turbo. If we had not done that we never would have found the REAL source of my leak.
Old Nov 10, 2008 | 01:56 PM
otpracer100
MAAAAN if my turbo is bad that is gonna **** me off like you don't even know. It seems like now that I need this truck for a daily driver anything and everything is going wrong.But........if the turbo is bad,no since in getting another stock one.....MUUAHAHAHA
Old Nov 10, 2008 | 02:20 PM
otpracer100
Anyone got a good turbo kickin around just in case? I see an h2e is outta the question at this time LOL!!
