glow plug LED mod on GPCM vehcle?
Old Nov 9, 2008 | 09:53 PM
willeo6709's Avatar
willeo6709
anybody ever done one? I ran the wires to where the relay shuld be but I have this big aluminum box..... looks like the glow plug wires are the 2 yellow wires on top of the front plug... anybody have a connector diagram? I'd hate to tie into the wrong wire. I am probably going to tie it off for tonight, finish putting the rest of the gauges in and tie in the LED when I know what I am doing.
Old Nov 9, 2008 | 10:03 PM
megawatt00's Avatar
megawatt00
I'll look it up for you Leo, I'll check the diagrams. now I'm curious..........
Old Nov 9, 2008 | 11:15 PM
willeo6709's Avatar
willeo6709
any help is appreciated Jim, I am running out of time tonight anyway....the correct wire for sure always helps. I really like the simplicity of the relay compared to this thing.... whats it supposed to do better?
Old Nov 9, 2008 | 11:40 PM
megawatt00's Avatar
megawatt00
It is on the CA models. "supposed" to cut dowm on pollution IIRC. If you have a bad glowplug then the controller will "tell" the scanner what plug is bad.
PM me your email address so I can send you the diagram it is to big to post here.
Old Nov 10, 2008 | 12:38 AM
willeo6709's Avatar
willeo6709
email sent.....
Old Nov 10, 2008 | 12:58 AM
willeo6709's Avatar
willeo6709
I just got the diagram..... should work out but it looks like I need to pick A glow plug to tie into, I can't just throw a ring terminal on top and tighten it down, looks like either cutting in and splicing a 3 way or taking the connector apart and soldering to the side of a pin before reinstall.
Old Nov 10, 2008 | 08:32 AM
megawatt00's Avatar
megawatt00
I agree Leo after looking at it myself the only feasable way is to tap into one of the glow plug wires. I would strip back a bit of the insulation and solder the wire for the led onto it. Retape it and you should be good to go.
