Replacement Shocks???
Old Nov 9, 2008 | 07:57 PM
ggwash21's Avatar
ggwash21
Ok i have a 2004 SC FX4 4wd and gonna be replacing my shocks i want to keep the good ride it had before they wore out, so what have you or would you replace them with? i dont do much towing if any at all.
Old Nov 9, 2008 | 11:41 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Monroe shocks from any major parts store is my plan. I've always had good luck with them, and they're reasonably priced.
if you're feeling frisky and have a fat wallet, people swear by Bilstien shocks.
Old Nov 10, 2008 | 09:35 AM
BrianFX4's Avatar
BrianFX4
I went with the Rancho 9000 series shocks and I like them alot.
Old Nov 10, 2008 | 11:13 AM
thirsty99's Avatar
thirsty99
'04 4x4 SC XLT. I replaced the stock shocks with Monroe Sensatracs. Keeps the ride quality, actually makes it better than the stock shocks, and they are not super expensive.
Old Nov 10, 2008 | 03:36 PM
Saleenguy's Avatar
Saleenguy
Are they a lot stiffer on compression and/or rebound?
Thanks
Old Nov 10, 2008 | 03:45 PM
BrianFX4's Avatar
BrianFX4
That is the great thing about the 9000 series it has nine different settings you can adjust to. I drive everyday with mine set at a 5 I think and it rides better than new. When offroad I crank them all the way down to 1 so I get full compression and extension. It did great up in the Rocky Mtns. while offroading.
Old Nov 10, 2008 | 04:34 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
I went with the Bilstien Yellow HD's! Like em allot!
Old Nov 10, 2008 | 04:51 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
do you have the in-dash controller?
and how much did that setup run you? I've always been interested in the 9000 shocks
roushcm's Avatar
roushcm
I went with the bilsteins. Then again, I wanted to level the front and figured since i'm already in there to just use 5100 shocks instead of a leveling kit. The ride is a little harsher on little bumps but the bigger bumps don't feel nearly as bad as when it was stock. If you get off road a bit, you will really notice a difference.
Old Nov 10, 2008 | 04:59 PM
silver05fx4's Avatar
silver05fx4
i look in to the adjust rancho shocks their about twice the price of a nomal shock which is a little to pricey for me
but glad to know that someone got them and really like them
Old Nov 10, 2008 | 08:55 PM
ggwash21's Avatar
ggwash21
Thanks guys i'm gonna do some more research on these Bilstien and rancho 9000's.... I have done alot of driving the last few days for deer season and my front end has iced up and now i heard and feel as if my shocks are bottoming out BAD..... so shocks are in store soon.... I'm gonna have my father check on shocks since he works at napa i get great prices....
again thanks for all the great points on shocks guys....
Old Nov 10, 2008 | 08:59 PM
ggwash21's Avatar
ggwash21
Another thing Does anyone know of anyone using the Rancho Quicklift shocks?
Old Nov 11, 2008 | 11:03 PM
Tk421's Avatar
Tk421
im getting ready to replace mine as well, 50k and i think still the factory ones ... rockauto.com and jegs seemed to have good prices.
Im a bitof a n00b though ... do i just buy 4 replacement shocks (all the same)? Obviously the fronts have the springs, does the shock come out independent of the spring for replacement?
Old Nov 12, 2008 | 03:09 AM
svt2205's Avatar
svt2205
Tk421, I'd suggest that you have a shop change out your fronts. You'll need a coil spring compressor to remove/replace the spring on the front strut.
I've had good luck buying from shockwarehouse.com
Old Nov 12, 2008 | 05:07 PM
roushcm's Avatar
roushcm
TK421, the fronts are different because of the coil over. The fronts aren't too hard to change if you take your time and use a good spring compressor. I bought my shocks from shockwarehouse.com. They are a site sponsor and seemed to have the lowest prices at the time.
