fuel filter?
Old Nov 9, 2008 | 07:59 PM
medhvac's Avatar
medhvac
Originally Posted by bigsteve1969
cps could cause noises? im probably gonna let the instructor drive it tomorrow and let him tell me what he thinks i just hope it aint injectors cause i cant afford um right now for sure. my only option would be to rebuild um
if its and injector problem,there probably not all bad!And i would stay away from the remans!jmo
Old Nov 9, 2008 | 08:26 PM
bigsteve1969's Avatar
bigsteve1969
hopefully its not injectors but im runnin outa things to blame it on
Old Nov 9, 2008 | 09:07 PM
medhvac's Avatar
medhvac
u could remove one valve cover at a time,then start the truck and remove the electrical connection one at a time at each injector,and if the one you removed made the truck quite.then u may have found the problem! Its not a bad idea thats how i found what injector was bad on my truck!
Old Nov 9, 2008 | 10:06 PM
87 F-150 I6's Avatar
87 F-150 I6
yea ever since starting with that motorcraft oil... it aint run worth a crap... atleast with the delo its not knocking!
IS it knocking more on the drivers side or the passengers side. It could be #8 injector not getting enough fuel. The sound would go away when you have the tuner because your putting more fuel in. I would try the CPS. Have you noticed the engine running differently or is just a sound change?
Old Nov 9, 2008 | 11:43 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Any chance of this being related to winter blend fuel?
My truck is night and day when they switch.
Summer time=purrs like a kitten
winter time=clack clack clack
Old Nov 9, 2008 | 11:52 PM
orng1's Avatar
orng1
Have you tried adding a little oil to the fuel, maybe some trans fluid?
Old Nov 9, 2008 | 11:58 PM
Powerstrokedlariat
When you had the predator in, did you run the crap out of the truck? I'm wondering if maybe you need to re-torque the injectors? Start small man, these trucks are tough. Dont go any furthur that necessary.
Old Nov 10, 2008 | 12:36 AM
Steve_250's Avatar
Steve_250
By any chance, did you get a gray CPS? There are known problems with it and the mother ship is "looking into it".
Old Nov 10, 2008 | 07:25 AM
bigsteve1969
im gonna do a black cps and new fuel filter today... I didn't run the crap out of the truck with the diablo. this noise started before winter fuel got here. it used to really knock and i changed the oil and it stopped. i also added the hpx and it helped a little. its still sounding like a constant clattering it wont do it in park while your revving its only moving down the road and responds as i push the go pedal so im just gonna keep checkin things off i guess
Old Nov 10, 2008 | 08:56 AM
big poppa's Avatar
big poppa
How about a good treatment of Diesel Kleen, mine was chattering and knocking pretty good, dumped some DK in, runs smooth with 5% bio blend.
Old Nov 10, 2008 | 09:15 AM
scottm1's Avatar
scottm1
What about a cracked flexplate? I'm not sure if this is a problem in the Ford's or not, but the Dodge Cummins are notorious for cracked flexplates that makes it sound like the engine is coming apart. Just a thought????
Old Nov 10, 2008 | 03:20 PM
bigsteve1969
good idea scott... that would be one of my last things to look at... I got my fuel filter but the cps was 112 and wasnt black.. it was a IH but it was grey/black so i didnt know if it was the right one.. didnt have time to do the fuel filter i was tied up with a cummapart all day
Old Nov 11, 2008 | 09:12 PM
  #28
bigsteve1969
well put in a new fuel filter in today and its helped most of the racket! heck for 18 bucks i may do a fuel filter every oil change and make it a even 100.00 service ha ha anybody know bout that cps? the black/grey one good or no it is a IH
Old Nov 11, 2008 | 09:35 PM
  #29
big poppa's Avatar
big poppa
Got this part no# from F-350 Chris off his thread, he did some research on the two,IN black CPS part #1825899c93 or the old black CPS part #1821720C99. I got the gray in mine and i,m getting a black one to switch out. Gray for the glovebox.
Old Nov 11, 2008 | 10:00 PM
  #30
bigsteve1969
so either black one?
