Horn question; box under dash
Old Nov 10, 2008 | 05:11 PM
fishindave11's Avatar
fishindave11
The cruise control works GREAT! I use it all the time. You can feel the "boing" if you put your hand on the box when you press the horn. So if this is the "speed control" box, then why is the horn mixed up in it??
Old Nov 10, 2008 | 06:16 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Horn and the speed control switches are powered by the same Feed wire from the horn relay. Circut #1 Blue/Yellow. If your steering wheel pad is defective, it theoreticly could send a signal to the speed control amp by mistake.
Make sure it's the speed control amp though. Like I said before, the Speed control amp has 12 wires coming out of it. the horn relay has only three.
stbernard
Jan 13, 2017 04:13 PM
Frank33884
15
Mar 23, 2016 10:29 AM
fabieber
Jan 31, 2016 01:17 AM
Virginiamv78
Jan 27, 2016 06:06 AM
f150crewcab
Oct 7, 2015 03:04 PM
