Cruise Control
Old Nov 8, 2008 | 11:00 PM
me Mickey C's Avatar
me Mickey C
Cruise Control
Hi, do any of you know about cruise controls? I am having a little problem with mine, it works but won't stay engaged, everytime I hit a bump it disengages, it's annoying ( especially when towing ). This is an aftermarket unit that was in the truck when I bought it.
Old Nov 9, 2008 | 12:35 AM
GenLightening's Avatar
GenLightening
Sounds like either the clutch or brake switches are getting triggered when you hit a bump. That would tell the CC that you're engaging the clutch or stepping on the brakes. Or, it could be a loose connection somehwere.
Old Nov 9, 2008 | 01:11 AM
rupejosh's Avatar
rupejosh
i agree with lightning i would start with the switches.maybe turn the key on and listen to see what it takes to make a relay click try shakin the brake pedal or something or just mess with the switch itself taht may give you an idea
Old Nov 9, 2008 | 07:38 AM
me Mickey C
I will check that today, I don't know what they look like but will get under there & try to locate them, Thanks
Old Nov 11, 2008 | 05:39 AM
Dieselamour's Avatar
Dieselamour
Is the bellows on a factory unit availabel seperately, or do you need to replace the whole thing.
Old Nov 11, 2008 | 05:20 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Mine did the same thing, before I replaced the VSS/Rear ABS sensor in the rear diff... Now it works great... Bumps and all!
fordtough81
Feb 14, 2012 05:34 AM
octaneforce
Nov 19, 2009 07:57 PM
RobbyMartin
1997 - 2003 F150
13
Nov 23, 2008 11:12 AM
STEVESMITHOCNJ
Oct 12, 2007 10:49 AM
