Odd ? concerning RPM's
Old Nov 8, 2008 | 05:41 PM
TDean's Avatar
TDean
This may be hard to understand, but here it goes. 93 F-150 5.8 Idling in park, if I romp on it, the rpm's seem to decrease slowly after it's throttled. After it's throttled, rpm's seems to hang unusually long back down to idle. Has been like that since I've had the truck. The decline of rpm's seems a little sluggish as though somethings interfering. Does this even make sense?
Old Nov 8, 2008 | 05:53 PM
TDean's Avatar
TDean
Here's a terrible, jerky video to demonstrate.
MVI_0666.flv - Video - Photobucket - Video and Image Hosting
Old Nov 8, 2008 | 05:55 PM
Conanski's Avatar
Conanski
Could be a sticking idle bypass valve, remove it from the TB, disconnect the solenoid from the valve and thoroughly clean with TB cleaner until the valve moves freely. Could aslo be a sticking throttle cable, you can disconnect the cable from the TB linkage and operate it manually to determine if the cable is the problem or not. It could also be the throttle valves themselves, they should snap shut when the throttle is blipped.
danr1's Avatar
danr1
I'd start by checking out this part,
Ford Fuel Injection Idle Air Bypass (IAB)
Ha! never mind, Conanski covered it.
Old Nov 8, 2008 | 06:02 PM
TDean's Avatar
TDean
Do you guys think its lagging, judging by the video? I removed and cleaned the IAC earlier today before I shot that.
Old Nov 8, 2008 | 06:03 PM
TDean's Avatar
TDean
Check, check and check. All good.
Old Nov 8, 2008 | 06:13 PM
danr1's Avatar
danr1
Looked pretty normal to me.
The IAC may be a little slow to react sometimes, that may be what you notice when <i>The decline of rpm's seems a little sluggish as though somethings interfering.</i> no big deal though. If it gets worse clean or replace it when you think it needs it.
I have to clean the one on my wife's explorer about every 4 months, replaced it twice even but I have yet to have a problem with one on ether one of my trucks.
Old Nov 9, 2008 | 05:26 AM
TexasGuy001's Avatar
TexasGuy001
Looks pretty normal to me too.
Old Nov 9, 2008 | 12:07 PM
jerg_064's Avatar
jerg_064
definitely looks normal, i guess when it hits around 1300-1400 it slows down a lil. could have a small vacuum leak somewhere.
Old Nov 9, 2008 | 12:17 PM
mstngmikegt's Avatar
mstngmikegt
I know with the programming in Mustang AT ECU's they are set to bring the idle down slowly (I believe that it is to help elimimate stalling on decel). It may just be normal stuff. Check the standard stuff....but it may just be nature of the beast when revved at idle under no load.
Old Nov 9, 2008 | 02:22 PM
TDean's Avatar
TDean
Thanks all. Was thinking it should be more responsive on the decline, as I was comparing it to another rig I previously owned.
Old Nov 9, 2008 | 02:24 PM
Opossum's Avatar
Opossum
Unless it's this lag is extreme or jerky is normal. The computer has whats called the idle air follower function. This function has the IAC follow the proggress of the throttle as you drive. And yes it's to prevent a stall then the throttle is snapped closed.
I personally hate this function. It makes going from full go to full whooh unpredictable and dangerus cause it effects the brake balance.
Old Nov 9, 2008 | 02:39 PM
TDean's Avatar
TDean
Owned a GM with 350 vortec and the throttle was excellent in every regard compared to my Ford.
Old Nov 9, 2008 | 03:34 PM
Opossum's Avatar
Opossum
Of all the vehicles I've owned my vortec 7.4 was the worst for this. Even with the hydroboost brakes it took way to much brake pedal pressure to hold the truck still for about 30sec after a full throttle romp. I even had situation on slick serfaces were it would powerbrake at this high idle, even with the locker. It was sometimes scary cause it would play havoc with the ABS and the front brakes would release.
