IM confused
Old Nov 9, 2008 | 01:21 PM
guitarnik's Avatar
guitarnik
IM confused
how do you get the upper ball joints off of a 90 f250. ill post pics in a minute. ive done ball joints before but these have me confused. i got the top nut off but cant figure out how to get the slotted nut off.
Old Nov 9, 2008 | 01:27 PM
quaddriver's Avatar
quaddriver
Its a <insert bad word here>.
may I suggest a railroad spike and some persuasion?
Old Nov 9, 2008 | 01:29 PM
guitarnik's Avatar
guitarnik
heres a pic
heres a pic of the dumb thing im talkin about<a href="http://s466.photobucket.com/albums/rr21/guitarnik/?action=view&current=11-09-08_1321.jpg" target="_blank"><img src="http://i466.photobucket.com/albums/rr21/guitarnik/11-09-08_1321.jpg" border="0" alt="Photobucket"></a>
Old Nov 9, 2008 | 01:35 PM
danr1's Avatar
danr1
You gotta take the bottom off with it, you can not just do the top ball joint leaving the bottom in place.
That is the caster/camber adjustment, it is rotated to adjust the position of the top of the knuckle.
Old Nov 9, 2008 | 04:08 PM
andym's Avatar
andym
There's no way you're getting that adjuster sleeve out without removing the knuckle. You have to unbolt both top & bottom ball joints. Then screw the nut back on the top ball joint stub. Beat it with a hammer until it falls off. If it doesn't come loose, get a bigger hammer. If you don't put the castle nut back on the stud, beating on the stud will mushroom it and you'll never get the knuckle off without cutting the stud.
Once you get the knuckle off, you can hit the adjuster until it comes loose.
Old Nov 9, 2008 | 04:12 PM
guitarnik's Avatar
guitarnik
i figured it out, i just wish there was an easier way to do this.
