Floor Jacks
Old Nov 8, 2008 | 04:56 PM
Turtlesplatter's Avatar
Turtlesplatter
Floor Jacks
OK...stoooopid question, but just have to ask. Just curious as to what should be the minimum weight rating for a floor jack to lift up my 05 150 SCREW? I have lifted up my brothers Yukon with one of those cheap 2 ton floor jacks from Auto Zone and it did the job. But am looking to get a decent priced floor jack for my garage but don't want to pay too much for a jack that's an over kill (I don't plan on lifting any deuce and halfs anytime soon!)
Thanks!
Old Nov 8, 2008 | 06:34 PM
guessrow's Avatar
guessrow
Turtle-
2 - 2 1/2 tonjacks are probably the minimum you would want to go. I use a 3 1/2 ton that I got quite reasonably from Sam's club. Another thing, the bigger you go the wider the stance gets and the higher it will lift. Shop aroud, you can find some good prices.
-jim
Old Nov 8, 2008 | 06:38 PM
Oldguy4's Avatar
Oldguy4
I bought a 2 ton floor jack years ago and have never had anything it can't lift. Not talking about those little mini floor jacks, but a regular size one. Mine is a Larson, never heard of it before and I've never seen one since. It's made in China of course but try to find one that isn't.
Old Nov 8, 2008 | 07:24 PM
98greensi's Avatar
98greensi
i have one of those 2 1/2 ton cheapy it does the trick and picks up one front corner or the rear end of my screw, but that is about it, my dad has had a 5 ton for years it does a good job and has never been to big to not fit under a vehicle. it's approximately 12-16 inches wide (front) 18" or so on the ears for the rear wheels and 2-2 1/2 feet long with a 6 inch lifting base it's less then 6 inches high when all the way down at the front. He got it for under a 100 bucks.
Old Nov 8, 2008 | 08:09 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I would be looking for a 2 ton at minimum. You are only going to be jacking up 1 corner at a time...so 2 ton would be more than sufficient...but bigger is better
make sure to not jack up the entire rear-end with the pumpkin
Old Nov 8, 2008 | 08:19 PM
98greensi's Avatar
98greensi
any reason why not too? or is it just not advised too?
Old Nov 9, 2008 | 12:36 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
says specifically not to in the owners manual
and some guys on another forum have actually ripped their diff cover by doing this. 9/10 times it is probably fine. but that 1 time you don't get the jack just right...presto, intant pumkin oil change
Old Nov 9, 2008 | 01:03 AM
pilot10's Avatar
pilot10
If you have the option get a high lift model (I think that's the name) It takes less pumps to fully extend it. I have one and it makes it's much quicker to get the truck off the ground. Also with my older jack I would have to use wood blocks on the jack to get the truck past the minimum jack stand position.
tim
Old Nov 9, 2008 | 12:09 PM
Turtlesplatter
I'm thinking of going with either this one for the price...
Harbor Freight Tools - Quality Tools at the Lowest Prices
...or this one for the lift range
Thanks!!!!
Old Nov 9, 2008 | 01:45 PM
play400's Avatar
play400
Thanks!!!!
I have both jacks. Mine both lift the same height but the longer 1 is easier to slide under my car and use. Have enough "head room" under the trucks the the shorter jack works just fine. Think mine are rated at 2T. Can't emphasis how important it is to get a large, wide jack so it is not tippy. We lift 1 end a vehicle with a jack and roll it around on it. I'd never consider doing that with aluminum POS I carry in my street car.
Old Nov 9, 2008 | 06:16 PM
80,93,99,06's Avatar
80,93,99,06
I wouldn't buy anything from harbor freight, at least anything that would cause injury if it failed
Old Nov 10, 2008 | 08:51 AM
Fishin76's Avatar
Fishin76
Just opposite, I have never had anything that i have bought from Harbor freight fail ( knock on wood). At the same time, haven't bought any jacks from them yet. I still would not be afraid to but one though..
Old Nov 10, 2008 | 04:12 PM
Saleenguy's Avatar
Saleenguy
A few years ago I got a great deal on a floor jack that says 2.5 tons, and 2 stands , all came as a set at Costco.
I am sorry but not able to look at it this moment, and forget the brand name.
But its yellow, and was a reasonable price for all 3 pieces, and it works very well.
Old Nov 11, 2008 | 10:50 AM
play400's Avatar
play400
Mine are not from Harbor Freight, small 1 is from a similar company, Princess Auto in Canada, and the large 1 is a name brand. Also have a Bluebird lift that will pick up the front or rear of a vehicle by the frame rails. Old school. All work flawless and other than 1 double action cylinder I have on my cherry picker, are just as fast.
I have found that overseas hydraulic cylinders theses discount sellers use usually have crap in them so we disassemble, clean and reassemble them before use. Also have to make sure all bolts are tight
Old Nov 14, 2008 | 12:12 PM
Buck 1's Avatar
Buck 1
At this time of year you can usually get a good deal on a floor jack at Sears. Craftsman makes a good jack at a reasonable price; and many automotive tools are on sale this month. I would stay away from any of the cheap ones........your life may depend on it!
