ICP testing
Old Nov 8, 2008 | 12:20 PM
TransplantX's Avatar
TransplantX
ICP testing
Besides unplugging the ICP while it's in place, is there a way to test the ICP while it's out of the truck with a VO meter?
Thanks
Old Nov 8, 2008 | 01:57 PM
Cuda_jim's Avatar
Cuda_jim
Maybe this will help:
You can check the IPC sensor in the truck KOEO
Diesconnect the GPR or wait till it cycles off
Wiring Check:
Measure voltage between VREF Pin B and battery ground.
Is voltage reading 5v ±.5?
Yes=OK
No= Repair wiring
Measure voltage between VREF Pin B and signal return Pin A.
Is voltage reading 5v ±0.5?
Yes=OK
No= Repair wiring
This is Measured KOER
Old Nov 8, 2008 | 02:08 PM
TransplantX
Thanks Cuda, I'll check all that when I get back from the kids ball game. quick question, if you can hear the the injectors clicking when the motor is turning over, does that mean there should be sufficent oil pressure in the HPO side of things?
Thanks
Old Nov 8, 2008 | 04:13 PM
Cuda_jim's Avatar
Cuda_jim
Rick, All that means is the IDM is firing the injectors. That doesn't mean the HPO is getting to them. The IPC and IPR control the pressure if the HPOP is producing pressure.
Old Nov 8, 2008 | 04:37 PM
TransplantX
I don't ever remember hearing the clicking of the injectors till today. I pulled the front oil rail plug on the right side and the ICP to bleed off some air. Thats when I was asking about testing the ICP. I went ahead and put it back together before any responses but left the ICP unplugged, and thats when I started hearing the injectors clicking. assuming there is enough oil pressure and fuel in the bowl, what else should I check / try?
Old Mar 18, 2010 | 04:25 PM
79f-250custom's Avatar
79f-250custom
could some one tell me how to do this in english please??? lol
what the heck does VREF and KOEO stand for?
thanks for any help.
Mitch
o and also do you do this while the truck is running or shut off?
Old Mar 18, 2010 | 04:32 PM
Action4478's Avatar
Action4478
VREF , is vehicle reference voltage (.5 V)
KOEO ., is Key on ,engine off...
KOER , is key on engine running...
Old Mar 20, 2010 | 10:28 PM
79f-250custom
thanks rick!
i got to get out there and check this. my CEL is driving me crazy!
Mitch
OneLostCowboy
Apr 7, 2017 12:01 AM
hawkco66
Oct 23, 2016 08:49 PM
ballbandit
Jul 11, 2016 10:52 AM
Fudgeon
Jul 9, 2016 04:33 PM
dchamberlain
Feb 12, 2016 05:08 PM
