Swapped a 2wd F250 TIB front suspension off my 1985 into my 1983 Bronco, it's going to be a sand buggy. It all bolted in real easy, took less than an hour from beginning to remove the coli spring TTB to finishing installing the TIB. Only problem is now I have an 8 bolt lug pattern on the front, and 5x5.5 in the back. Not really an issue for my intended purpose.
Never seen anyone go backwards like that, very interesting.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
