351 motor codes????
Old Nov 6, 2008 | 08:25 PM
dieselaholic's Avatar
dieselaholic
351 motor codes????
Ive got a 92 250 and it runs ok for a while and then throws 3 codes up. It will run fine as long as you run it easy but if you give it a little hell it warms up a little. The check engine light wont be on for a while and after it warms up good it will come on. the codes i get are 28) VAT sensor out of self test range, 32) EVP ciruit below minimum voltage of .24 volts, 83) EGR control solenoid failure, high speed electro-drive fan circuit failure, and low speed fuel pump relay circuit open. any suggestions???????
Old Nov 6, 2008 | 10:36 PM
Conanski's Avatar
Conanski
VAT stands for "vane air temperature" which equates to the ACT sensor on these trucks. The other 2 are EGR related so I'd suspect the EVR is malfunctioning.
Old Nov 7, 2008 | 05:20 PM
dieselaholic
would the egr malfunctioning be responsible for it getting a little hot when i go and give it a little hell?? Or is thier no relationship?
Old Nov 8, 2008 | 10:03 AM
Conanski's Avatar
Conanski
Anything is possible, best to find and fix your problems, clear the codes and see what difference it makes.
Old Nov 9, 2008 | 06:00 PM
dieselaholic
I think i found that problem, my vacuume line going to the egr valve has a crack in it. but it still acts like it runs a little warm but not hot.
Drac
Jun 29, 2016 09:18 PM
run6.0run
Jan 5, 2016 07:34 AM
mudbug3854
Nov 29, 2010 03:37 PM
Fwayz
Aerostar
Apr 20, 2004 04:47 PM
plapczynski
Feb 4, 2004 03:50 PM
