wicked wheel install
Old Nov 7, 2008 | 08:43 PM
huntke's Avatar
huntke
Originally Posted by big poppa pump
What freaked me out was sticking a long screwdriver through the exhaust side to bind that wheel while you work the WW bolt off, jeeeess, i thought i was bending the turbines..
you got that right.....I'm still waiting for something to show up from that one. I didn't much like doing it that way but it's what everthing said to do from what I have read and it all worked out okay....
Old Nov 7, 2008 | 08:52 PM
big poppa's Avatar
big poppa
Not that i advise it but pull that red line off the wastegate and take it for a ride, you think it sings now, listen to it with the line off, wicked. I tried it but i put it back on, i was getting some bad mpg,s with it off the wastegate.
Old Nov 8, 2008 | 06:39 AM
redfire42's Avatar
redfire42
Can you notice a differance driving emty or is it just when towing? Xtream diesel has it for $60.
When I do it I will just have to get some local FTE'Rs to come and lend a hand..
Old Nov 8, 2008 | 07:16 AM
big poppa's Avatar
big poppa
On my truck you can hear it when you get on her a bit and when towing, you hear it constant. Before you order from them, check to see if they got it in stock First. They sell those things fast so check first before paying!! Also, if you need help with anything, PM me
Old Nov 8, 2008 | 07:24 AM
redfire42's Avatar
redfire42
Thanks for the info Mike and I will let you know if I need help. How long did it take you to do yours?
Old Nov 8, 2008 | 07:32 AM
big poppa's Avatar
big poppa
No problem. I took my time considering i never did a WW before, a little over 3.50 hours or so. I would have done it faster if i had the 12 point 3/8 socket, had to run and get one.
Old Nov 8, 2008 | 08:41 AM
trike1946's Avatar
trike1946
I am planning on doing this next month when work is slow. What if the bearings are bad?
Old Nov 8, 2008 | 08:50 AM
big poppa's Avatar
big poppa
Then a repair kit might be in order before you install the WW. To test, you grab the wheel and push in and out side to side,shouldn't be any play, very minimal if any.
Old Nov 8, 2008 | 09:08 AM
trike1946's Avatar
trike1946
Does the whole thing have to come out for the repair kit?
Old Nov 8, 2008 | 09:15 AM
big poppa's Avatar
big poppa
I believe so but some other members will be able to confirm that for sure, never had to do that. What makes you think you have to rebuild???
Old Nov 8, 2008 | 09:19 AM
trike1946's Avatar
trike1946
I am not sure if it is bad. I have a fairly loud whine that pulsates at 50-65 mph. I have poor hearing and wear 2 hearing aids, so I have trouble finding a source for noises. Actually I was wanting it to be the turbo and not something like the rear. Nobody I have taken it to has any idea what it is.
Old Nov 8, 2008 | 09:37 AM
big poppa's Avatar
big poppa
Did you make sure all your boots are tight,IC and Plenums, no air leaks. If it seems like its coming up front, that could be your problem. Just looking at all the trucks you own, i shouldn't have to explain.
Old Nov 8, 2008 | 05:49 PM
  #28
trike1946's Avatar
trike1946
My problem is I don't know where the sound is coming from. I only hear it when driving. I have no sense of direction when it comes to noise. I always take it to be in front of me. From having to fix all sorts of things on the trucks I have some reasonable knowledge of basic things to try. But nothing has changed. None of the other trucks makes the noise. My other 01 has more miles and no noise. It doesn't start til 50 and goes away about 65 or so. It is fairly loud. How does a bad bearing sound in the turbo? Would it make a noise all the time?
Old Nov 8, 2008 | 05:54 PM
  #29
schlepprock250's Avatar
schlepprock250
I had an uppipe leak that sounded like a pulsating policemans whistle,I tightened up the leaky joint and it stopped,(I had just replaced my uppipes with the bellowed ones).When I was hard into it,it made it louder.
Schlepprock
Old Nov 8, 2008 | 06:11 PM
  #30
trike1946's Avatar
trike1946
That is what it sounds like. Was it constant? Mine is not.
