Hard Start-Long Cranking
Old Nov 6, 2008 | 11:43 AM
02X72's Avatar
02X72
When I go to start my truck(02 7.3 Excursion) it is recently taking a good 4-6 seconds of cranking to start. Once it does though it runs fine. I am thinking it could be because the glow plugs are going bad? It has enough oil, been through that already. What should I start with?
Old Nov 6, 2008 | 12:58 PM
Action4478's Avatar
Action4478
(If you have one)
Clamp a jumper cable clamp in the two large posts on the GPR If you have a controller ,,then If it was bad ,may set a light ...
Old Nov 6, 2008 | 02:40 PM
F350-6's Avatar
F350-6
I'm with Rick. I thought the Ex's all came with the GPCM which should set a light for either a bad glow plug or a bad controller.
What happens if you leave the key on for 20 - 30 seconds before you try to start in the mornings? Does it start any better that way? If not, you could ohm the glow plugs to get readings on them.
Old Nov 6, 2008 | 04:12 PM
PwerStroke99's Avatar
PwerStroke99
weak batteries maybe???
Old Nov 6, 2008 | 06:29 PM
westpsd's Avatar
westpsd
Put a voltage meter on the 12 volt system. Turn the key to on...the voltage should read 12 to 12.4 with the key off, 11 to 11.5 with the key on (if the glow plugs are working) and not drop below 10 while cranking (provided the batteries and starter are good). Problems like this require a systematic approach to trouble shoot. This test will at least get you in the right place to look. Weak batteries, poor cable connections, bad starter, bad glow plugs or bad glow plug relay can all cause your symptoms. You just have to check them all till you find the culprit.
Jim
Old Nov 6, 2008 | 07:01 PM
DemonRace6's Avatar
DemonRace6
Hi!
This has been happening with my truck recently also, I have very good brand new batteries, only difference is my truck sits for 5 days every week, Monday-Friday, I am in school.
What are: GPR and GPCM?
Old Nov 6, 2008 | 07:20 PM
F350-6's Avatar
F350-6
GPCM is the glow plug control module installed on CA emissions trucks (99.5 & later) and excursions. GPR is the glow plug relay and looks like this
Either one is basically just a switch that sends power from the battery to the glow plugs. The wire with the rubber boot over it is the battery feed. The other large post is what sends the voltage to the glow plugs when the "switch" is thrown. You can hold a screwdriver across the 2 large posts for 30 seconds before you try to start the truck. If it fires right up after that, you probably need a new GPR. You can also check voltage output immediately after the key is turned to the ON position.
Old Nov 7, 2008 | 03:37 PM
02X72's Avatar
02X72
Well , the GPR seems to be the culprit. Connected the larger terminals with a screw driver and it fired right off. Thanks for all the help guys, you again saved me time and money.
Old Nov 7, 2008 | 04:17 PM
SpringerPop's Avatar
SpringerPop
If you're going to replace it, and never want to do it again, see this:
Welcome to guzzle's Stancor GPR replacement Mod Web Page
About $45 here:
http://www.mouser.com/search/Product...key802-586-902
None of that cheap copper stuff, they're SILVER!
Pop
Old Nov 7, 2008 | 04:29 PM
Action4478's Avatar
Action4478
More reps due,,but you know the story ,,,
Does that mean I'm in jail?...
