backup light switch
Old Nov 6, 2008 | 11:23 AM
mongoosekeith's Avatar
mongoosekeith
backup light switch
Ok my truck had a 3 on the tree tranny and the previous owner put a four on the floor with granny gear and i can not find the switch on the tranny or the original plug that plugged into the other tranny. So if any of you guys know any help will be greatly appreciated
Old Nov 6, 2008 | 12:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
With a 4 speed, the backup light switch screws into the shift tower = 1967 and later. 1966 and earlier trucks did not have backup lights.
If the trans is from 1967 and later, it has a backup light switch.
New Process 435: The switch screws into the part of tower the shift lever fits into-drivers side.
Warner T-18: The switch screws into the tower, behind the portion of the tower the shift lever fits into-drivers side rear.
C9TZ15520C .. Backup Light Switch-2 Male Connectors-Use with Warner or New Process 4 Speeds (Motorcraft SW840)
This is just a simple switch, and it's most likely still there, because if it wasn't, gear oil would be spewing from the threaded hole it screws into.
The wire harness that plugs into the backup light switch is part of and feeds off the taillight wiring harness that runs along the left frame rail.
Old Nov 7, 2008 | 11:04 AM
mongoosekeith
Ok thank you. i was hoping you would respond cause you seem to know the most out of every one that i have run across
CCope94
Jul 31, 2012 06:44 AM
Dutter
1983 - 2012 Ranger & B-Series
Feb 9, 2011 05:48 PM
Canuck77f150Ranger
Oct 31, 2007 10:13 PM
r7salvation
Electrical Systems/Wiring
Dec 15, 2004 09:49 PM
Monsta
Jan 25, 2002 11:45 PM
