Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Bottle jack press
Old Nov 6, 2008 | 10:53 AM
SGnAZ's Avatar
SGnAZ
Bottle jack press
Hey all,has anyone ever used a bottle jack as a press? I was thinking of rigging one up to use on bushings and such.Any thoughts?
Old Nov 6, 2008 | 08:39 PM
Ford_Six's Avatar
Ford_Six
Are you planning on building a frame around it and using it as a press? I don't know how much you'd save over just buying a press. I have this one from the cheap junk store: Harbor Freight Tools - Quality Tools at the Lowest Prices and it works ok. Powerful enough to do wheel bearings, and I also made a can crusher tool that fits in there.
They also have this one for the benchtop, although I've never used this one: Harbor Freight Tools - Quality Tools at the Lowest Prices
Old Nov 7, 2008 | 02:18 AM
Super Steve's Avatar
Super Steve
I have used a bottle jack.
I placed the part between the jack and my truck frame and pumped away.
It worked in a pinch since I dont have a real press.
I've used ones like that hf 150 dollar model and they are nice. Much easier than trying to balance the part between the jack and the frame. It just isn't on the top of my needs list right now.
Old Nov 7, 2008 | 05:51 AM
wiseguy's Avatar
wiseguy
I was thinking about buying one of the harbor Freight or Norther presses, but was leaning more toward the 20 ton press because it could handle longer items. What's everybody's experience? Is it worth getting the 20 ton, or has everybody been able to get by with the 12 ton with no problems?
Old Nov 7, 2008 | 07:17 AM
SGnAZ's Avatar
SGnAZ
I was going to build a frame for it but, after seeing those presses it would probably be more cost effective and time saving to just buy one.Do you have yours mounted to the floor? I have a post tension slab in the garage so no drilling allowed.Maybe the bench mount is the way to go.
Thanks
Old Nov 7, 2008 | 11:19 AM
daveengelson's Avatar
daveengelson
It would seem too time consuming and labor intensive to rig a devise for each application. Suggest 1st check on Criag's list, may find something local and save on shipping. Came across a 20t press, including several plates and accessories, dirt cheap surfice to say it was a good deal. Can also consider posting a 'wanted' in craigs list, but still check the ads. Also put wheels on the press.
Old Nov 7, 2008 | 11:24 AM
Super Steve
That sucker barely costs more than a dollar a pound. Factor in the costs of steel, the jack, labor, spray painting, subtract for chinese craftsmanship, and it still comes out cheap.
The bench top one looks nice and compact, but it's capacity would make it's uses very limited. I don't think you would be able to do any jobs bigger than pressing studs into a brake disc.
The big one would fit axles, long parts, wider parts.
And it doesn't have to be mounted, it just kicks it there like any other piece of shop equipment.
Which just gave me an idea. If I ever get one I think I will mount wheels on it so I can move it around the garage and roll it back to the tool storage area when not in use.
Old Nov 7, 2008 | 12:34 PM
Rockstone's Avatar
Rockstone
Thanks
My next door neighbor has this same unit, we have used it many times. As we have post tension slabs as well, it is not mounted to the floor, and has not been a problem at all.
Old Nov 7, 2008 | 07:30 PM
Ford_Six's Avatar
Ford_Six
I didn't mount mine, since I didn't have a slab in the garage. It worked just fine. When you put it together, tighten it up good, since they like to rack (twist out of square) under pressure. On mine, I'm thinking about putting cables on the backside in an X to brace it.
Old Nov 7, 2008 | 08:39 PM
four4x4fords's Avatar
four4x4fords
I have the Harbor press too. Had a heck of time getting it square and had to beat on it with a single jack for a while to get it right. Been a real good unit since then.
Like most other tools, you will be surprised at all the uses you find for a press after you have one.
Old Nov 8, 2008 | 03:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have one like the 20 ton harbor freight unit.
then i put a 30 ton air over bottle jack on it.
it works quite well.
scooterspal
26
Sep 18, 2018 07:50 PM
SARDiverDan
26
Feb 8, 2014 05:06 PM
papadelogan
Jan 31, 2009 12:43 PM
Aftrmidnite
Garage & Workshop
Feb 27, 2004 09:06 PM
