C6 Alternative replacement
Old Nov 6, 2008 | 07:32 AM
timcos's Avatar
timcos
I have a searched a number of terms and differing combinations of terms.
I have not found it answered anywhere....but...here goes...as if the title did not give it away already.
I would love a 4th or even 5th gear in my F250, 2WD, 6.9 IDI....I have the stock C6. Well I think I do...I am sure it has not been replaced to this point.
In essence, I want to get the RPMs down when on the highway.
What are my options?
Tim
Old Nov 6, 2008 | 08:15 AM
stuart1's Avatar
stuart1
You can't do diddly squat about lowering the high gear ratio in a C6 transmission.
For that you must think out of the box.
Other than installing an aftermarket overdrive system you can look at differential ratios and taller tires.
A bolt on overdrive costs lots of money.
Gear vendors make one at around $2500.00.
Old Nov 6, 2008 | 09:58 AM
timcos's Avatar
timcos
So no replacement tranny?
Tim
Old Nov 6, 2008 | 11:31 AM
stuart1's Avatar
stuart1
Yes you could install an E4OD but would need a stand alone computer.
Old Nov 7, 2008 | 12:52 AM
Thunderjet4x4's Avatar
Thunderjet4x4
Thats a tough one, nearly all automatic overdrives have an weak spot-and it takes big $$ to keep them alive. I too have a C6, behind a 429-and would love overdrive, but the cost, vrs. the amount I drive it, I might as well accept what I have.
For me, I might be able to build up an AOD trans, with an adapter to fit, but to go through the trouble, and cook the custom trans would slay me. Vrs. using a good ol cheap C6-that will last for years.
Another option would be a newer 5 speed-standard, but the effort and cost is high again.
These days, it seems if you must have a diesel truck, and auto overdrive, your best off finding a newer truck, factory made with all the good stuff.
sad but true.
However the gear vendors unit is very strong, and would most likely out last the diesel even.
Old Nov 10, 2008 | 09:25 PM
the_hetz's Avatar
the_hetz
Old Nov 11, 2008 | 12:16 AM
85e150's Avatar
85e150
Originally Posted by the_hetz
I suppose...you could put faster rear end gears in and use that low gear planetary for the C6 that tci makes. Still pretty expensive at over $700 just for the planetary...and you still only have 3 gears, but wider and less rpm in high.
I don't know if anybody makes a plate to put an AOD on an IDI or not (aren't they their own pattern?)...but if they do, definitely get a beefy one and put lower rear end gears to give that AOD as much advantage over the tires as you can stand!
Hah! Put a manual valve body in that C6 and find a two-speed rear end out of a truck! That would be freckin AWESOME!
Forget the AOD. The E4OD would be the one. Forget the truck two speed axle--waaayyy too big to fit under an F250 or even 350/450.
Gear Vendors is the best option. You'll save fuel with any OD, but you're not going to save money.
drunkdave
1978 - 1996 Big Bronco
Aug 10, 2010 09:43 PM
banjopicker66
Aug 24, 2006 07:25 AM
ttriley
Jan 30, 2006 12:32 PM
77finleyranger
Jun 16, 2004 12:46 AM
