maximum safe boost
Old Nov 5, 2008 | 05:21 PM
Power Smoker's Avatar
Power Smoker
Red face maximum safe boost
I've dropped the compression with a little piston bowl work, have a performance cam, and am doing 285 cc injectors. I'm doing some testing on a prototype compound setup from industrial injection running a phat shaft 62/70 with S400. The setup should be able to provide at least 80 psi boost, but I'm afraid of causing other damage even with slightly lower compression. does anyone have experience with the thresh hold of the heads with studs and/or fire rings? I can regulate the wastegate to whatever, and will probably go about 60 psi, but would like to know the limit. Thanks
Old Nov 5, 2008 | 05:43 PM
adambomb's Avatar
adambomb
285cc INJECTORS
80 PSI BOOST
IDK man but i just wanted to say you have a sick truck.
if i remember correctly i think the shop that did my ARP studs and unbranded "racing/sled pulling" gaskets (they didn't give me any info on them except they were really good) that it should hold 45-50psi
fire rings should hold more but i don't know how much.
consider my post a addaboy shout out on your truck and a bump to see if others can help you out.
Old Nov 5, 2008 | 05:44 PM
adambomb's Avatar
adambomb
computer messed up.
Last edited by adambomb; Nov 5, 2008 at 05:45 PM. Reason: computer messed up when i was editing
Old Nov 5, 2008 | 05:58 PM
3000 FPS's Avatar
3000 FPS
I have no idea what boost to run but let us know what horse power ratings you get and if you run it on the quarter mile what kind of et's you get.
Old Nov 5, 2008 | 08:07 PM
Power Smoker
I'll be sure to keep you posted. I've got an EBP gauge to figure out turbo efficiency, so I guess I'll go from there. 1/4 mile times were mid to high 14's with the best dyno of 501 rwhp, 977 rwtq w/ 165 cc's & single 62/70 turbo. We'll see what the 285's & compounds will do... similar setups have had at least 600 rwhp.
