So today I decided to grease up the bearing on the front wheel the, but here lies my issue. I have never done a 4x4 job. so i disassembled the 4x4 hub got the inner and the outter, gears out, removed the brake caliper and still could not get anything out, rotor, inner and outter bearing nothing! what's going on, and once I asslembeled the hub 4x4 does not work pfft ( that is me shooting myself in the head).
once you get the inner hub out there is a hub nut that must be removed with a special 4 prong hub socket well actually there is 2 nuts , theres the first one then a locking washer then another nut then the hub and caliper will come off.
yeah def get that special socket it will make it alot easier! i managed to get the nuts off without one but i will be purchasing the socket to reinstall!
