Sponsored by: Kumho
sorry, another shock question help!
Old Sep 20, 2002 | 03:55 PM
cwade3's Avatar
cwade3
i know the broncos are short wheel base and that effect the ride but here in louisana the roads are c@%p! i'm not sure whats on mine now except they are yellow,has no identification. would like info on some shocks that may help smooth the ride some my teeth fall out after a 15mi ride. this is a stock 95 bronco with all terrain 30x9.5 and i do some offroading nothing serious and not alot. plus the budget does have a limit thanks for anyones input.
Old Sep 20, 2002 | 08:29 PM
Johnny1369's Avatar
Johnny1369
Sounds like you may have some Monroe Gas-Magnums on there right now. If the ride is too firm, try the Monroe Sensa-trac. It gives you a smooth ride under normal ride conditions then stiffens up if you drive the truck hard off road. The Sensa-Trac has some type of special valving inside that provides a dual purpose. Stay away from junk like Gabriel. HTH.
Jon
Old Sep 21, 2002 | 10:59 AM
cwade3's Avatar
cwade3
[updated:LAST EDITED ON 21-Sep-02 AT 12:01 PM (EST)]thanks for the reply jon, i did get similar ones for my transport from midas. i let them do that work i havent had much luck working on that van always costed more at the end. they had the valving in those that helped just wasnt sure about the bronco with the 6 shock set up. i dont like the gabriels either.
Old Sep 21, 2002 | 07:14 PM
MustangGT221's Avatar
MustangGT221
You have a quad shock setup on there right? Thats what siffens the ride a little bit. I don't have the quad shock setup, and went from worn out stock shocks, to Rancho RS5000s and was suprised how much a shock can stiffen the ride.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Oct 19, 2002 | 11:13 PM
cwade3's Avatar
cwade3
mustanggt221 do you like those 5000 i havent heard to many responses on that shock, i have been considering those but have been leaning towards the monroe. yes i do have a quad set up.
Old Oct 20, 2002 | 12:49 AM
MustangGT221
I do like the shocks. I liked them because the price was right and they have a great reputation. I was going to buy some monroe reflex shocks but they were around 50-60 a piece. Ranchos were 35 a piece.
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Oct 20, 2002 | 12:51 AM
MustangGT221
Broncobudy
1978 - 1996 Big Bronco
32
Nov 23, 2005 04:10 PM
jerseydevil
Jul 8, 2005 11:14 PM
anollmann
Mar 11, 2003 04:25 AM
Bomber_Boy99
Feb 15, 2002 11:59 AM
bronco99
Jul 28, 2001 01:44 AM
