3.8 IMRC issues
Old Nov 5, 2008 | 08:41 AM
95strokenonby's Avatar
95strokenonby
3.8 IMRC issues
Have a 96 Windstar, 3.8L with codes for IMRC stuck open. It idles poorly and stalls coming to stops. Picked up some used control valves from junk yard but still same problem. My Snap On scanner is saying to check return springs? There aren't any return springs. Had to purchase new control solenoid because vacuum conn broke trying to remove hose. Have good vacuum, voltage and gnd at solenoid. Put vacuum to each valve but could not override spring tension which is keeping the valves open. They move freely and bushings are still in place. Anyone got any suggestions?
Old Nov 5, 2008 | 10:44 AM
Franklin2's Avatar
Franklin2
You have two of these things on the engine correct? You should get seperate codes for each bank. Which bank is giving you the codes? IMRC =Intake Manifold Runner Control.
hancockr
1983 - 2012 Ranger & B-Series
Sep 15, 2015 07:18 AM
smhamilt
3.8 & 4.2L V6
Nov 30, 2013 10:49 PM
bprime617
1997 - 2003 F150
Jan 9, 2012 02:05 PM
