Sponsored by: Real Truck
replacing tie rods
Old Nov 4, 2008 | 09:33 PM
ponch37300's Avatar
ponch37300
replacing tie rods
I am going to be replacing my tie rods. Is there any special tools or tips on doing this? Thanks for your advice.
Old Nov 4, 2008 | 10:07 PM
ReAX's Avatar
ReAX
A pickle fork is nice, an air powered pickle ford is better, but a good hammer will work. Take them out in one piece, don't loosen the tie rod sleeves until you can get into a position to set the new ones at the same length. If you have new sleeves, set them side by side, if not, you will get pretty close counting threads. Then you will need an alignment. You can use a tape measure to get close enough, set it up so the front of the tires are about 1.5" narrower than the rear.
