Sponsored by: Real Truck
abs light
Old Nov 4, 2008 | 09:16 PM
lordluke's Avatar
lordluke
abs light
iv got a 2000 2wd suuper duty f250 and my abs light just came on. no problems that i can tell of just driving it, iv read a few post and i think it might be a dirty sensor. it has raindthe past few days and i did have a little fun on a muddy raod today. ( v10s are mor fun) were do i check the sensors ? fron and rear. and could it just be a dirty sensor or something major.? any help whould be great.
Old Nov 4, 2008 | 09:32 PM
ReAX's Avatar
ReAX
did the speedometer act up? If yes, then it's most likely the VSS on the rear axle. If not, then the VSS is probably not the problem. With the ABS disabled you might not notice any change until you lock up the brakes.
Old Nov 4, 2008 | 09:35 PM
lordluke's Avatar
lordluke
no the speedo has been acting fine. evrything seems ok.
Old Nov 4, 2008 | 09:43 PM
ReAX's Avatar
ReAX
You may just have trash built up on the front tone rings or a little water in the sensors/connectors.
