Floor pan question
Old Nov 4, 2008 | 06:45 PM
mudder460's Avatar
mudder460
Floor pan question
I am getting ready to order and replace both side floor pans in my 77. My question is, there is a hole in the passenger side floor pan. It looks like it has a tranny mount bolt or something slightly sticking up through it. Now I know I need to replace my worn out body bushings as well. But will I have to drill a hole in my floor pan for this to come through or can I not worry about it? Thanks!
Old Nov 7, 2008 | 11:52 AM
73FOMO's Avatar
73FOMO
Don't think there should be anything sticking through. Sounds like you have some cab bushings that are shot causing something to push through? I will look at mine again tonight, my interior is gutted, but almost 100% sure there is nothing poking through.
Old Nov 7, 2008 | 02:30 PM
NOCO77's Avatar
NOCO77
I don't remember anything like that on mine either - you're going to have to crawl under there and take a look and give us a little more info to go off of.
Old Nov 8, 2008 | 05:41 AM
bucks77ford's Avatar
bucks77ford
There shouldn't be anything sticking through the floor. The only hole I know of is the small drain hole plugged with a rubber gromment.
Old Nov 8, 2008 | 11:14 AM
mudder460's Avatar
mudder460
If you go in my gallery I have a pic of the floor pan in there. The drain hole in on the right and then there are 2 holes or somethinf on the left.
Old Nov 8, 2008 | 11:38 AM
TexasRho83's Avatar
TexasRho83
I think someone got pissed off while riding shotgun and probably discharged their shotgun inside the cab
