differential pressure valve?
Old Nov 4, 2008 | 02:32 PM
learpilot's Avatar
learpilot
I have on my truck a DP valve which I have id to have come from a 75-79 f150. It has been inactivee for a number of years and open to the air. Now that I am putting the brake system back in operation I find the valve will let no fluid to the rear wheels and I suspect the valve is rusted inside and I think this is a ball on a spring which has frozen in place, But I am just guessing. Is this correct? and Can I disassemble it and free up the inner works or just bite the bullet and buy another.? Thanks
Old Nov 4, 2008 | 02:58 PM
Old F1's Avatar
Old F1
What? If this is around a 1980 that would be to early for anti-lock brakes wouldn’t, and if so they would have to work with the front brakes and a controller? So what is this thing? I think (?) it might be a superficial item or should that read a sacrificial item.
Old Nov 4, 2008 | 04:01 PM
learpilot's Avatar
learpilot
The valve is there because the front end has been replaced with a torsion bar (labaron) frontend which has disc brakes on the front and drums on the rear, thus the need for the Differential valve.
Old Nov 4, 2008 | 05:34 PM
4tl8ford's Avatar
4tl8ford
If the valve is not adjustabe it would be a 10PSI residual valve there should also be one for the front at 2PSI.
The adjustable valve is optional and is a Bias or proportional valve.
It's brakes - which means lives - which = replacement.
cyclone3565
2004 - 2008 F150
Oct 14, 2013 02:09 PM
johnson2007
Aug 21, 2011 11:39 PM
wtroger
Apr 16, 2011 07:54 PM
lance65
19
Apr 30, 2010 03:31 AM
biederboat
1978 - 1996 Big Bronco
May 1, 2005 08:06 PM
